Originally Posted by IceAged
Yes - as 'easy' as going outside and taking a photo of the night sky with a real camera. The end product however will not look very impressive unless you invest the time into understanding how the camera works under those sort of conditions.
Being a sort-of 'simulated camera', Fry will produce drab looking images if you simply 'point and shoot' - just as a high end camera in real-life will not necessarily give you stunning photos using the default settings.
So with FRY do you still have complicated render settings like in Vray? choosing the subdivision amounts, noise thresholds etc? and how is the light controlled, is there a selection of omnis and suns that you input?
Going outside and taking a photo of a building i modellled in max sounds really easy, and realistic - since its a photo - even if it were to look flat or dull, photoshop could be used aswell to touch it up...?
