Re: Night sky in FRY - NOT POSSIBLE?
"In fryrender and other unbiased renderers, the longer you let the image render, the higher the quality and you can stop it at any time."
so you would specify a certain image size e.g. 640x480 pixels and it will start rendering until you tell it to stop?
This software sounds very interesting, what is the render time compared to a vray rendertime, just a very rough estimate would it take alot longer or about the same? and is it a plugin that runs inside max or do you export a mesh and open it up in FRY and finally what size is the installation file?
