| Work in Progress (WIP) Post your works in progress here to get user feedback and critiques. |
hey every one.....i am kind knew here....i am posting image from a convetion center that i am working on...the thing is, i modeled in a different scale....what i did was, 1 unit = 1 millimiter..i am wondering,does it matter in that orbit scale parameter...i never care for thar parameter anyway...
thanks everyone... http://www.cgarchitect.com/forum/fil...le=teste.2.jpg
"just on saturdays...." |
Oi, Marcos!
I can tell you this: scale matters a lot. When you work using the proper scale, radiosity gets easier to set, photometric and standard lights work right, blocks you download from the net come in the right size... All you do is win. Also, you can then set which unit you want to work using the Display Units Setup dialog. That way, if another person in your office wants to work in a file you did, but prefers to work in meters instead of milimiters, no problem. Just change the display units and you're set. [] Rick |
Name: Victor Erthal |
It matters a lot if you are using radiosity with photometric lights. Since it is based on a real world light, its decay is very precise, and not only that. So i recomend you to setup properly you units (if youre using max of course) Using milimeters? ok, setup for milimiters. Cause if you units are in cm and you work in mm , you will have trouble.
valeu rick e victor
i guess i used mm because that´s the way people used to do in the office i used to work...i´ll do im meters from now on... i am using vray by the way...vray´s skylight + max´s sunlight...vrayshadow any coments in the project/image ..would be great for me... valeu negada!
