Old January 18th, 2007   #1 (permalink)
Koper's Avatar
Name: AdriaaN van Jaarsveld
South Africa
Default vray light seen in the glass reflection
doing and interior night scene and the light is basically set up but fo one thing , i get a reflection in the glass of the vray light i used for some backlighting.
have tried everything i can think of, it's set to invisible, the glass is excluded from the light and in the object properties it is set so it won't render.
i have read a previous post here about the same probl. but can't find it, think anyone might have the solution??
thanx
Koper is offline
Old January 18th, 2007   #2 (permalink)
kippu's Avatar
Default Re: vray light seen in the glass reflection
uncheck affect specular for that light
www.renderviz.com
kippu is offline
Old January 18th, 2007   #3 (permalink)
Jim Mann's Avatar
Its a new switch that they added to the Vray lights for 1.5. It caught me out too at first, I thought that I was getting bad render artefacts.
Jim
Jim Mann is offline
Old January 18th, 2007   #4 (permalink)
Koper's Avatar
South Africa
thanx ya'll, i'll go check it
Koper is offline
Vray glass too dark guitarboy VRay Render 13 January 19th, 2007 12:05 PM
Vray Pendant Light kwerch VRay Render 3 May 9th, 2006 07:28 PM
Vray light mzex VRay Render 7 August 23rd, 2005 06:22 AM
Vray Glass Issues arnold@asylumstudio.co.za VRay Render 2 October 7th, 2004 02:14 PM
3dviz volume light beams through glass? chadsmith Autodesk VIZ 2 January 26th, 2003 07:32 PM
