Old January 24th, 2007   #11 (permalink)
phix95's Avatar
Default Re: Some basic architectural questions
Hey, thanks for that. I'll check that out in the prog. I've been through the very basics in Autocad and havent looked at VW yet, but as far as the more complex things, like balustrades, cornices and the like, are those library objects at all or are those made from scratch?
phix95 is offline
Old January 24th, 2007   #12 (permalink)
Indonesia
Oh yes, complex things usually start from scratch. Unless you have something very common in a geometry, you can't use library. I even remodel existing library because it cost me more time to adjust rather than build it.
_ _ _ _ _______________________ _ _ _ _
http://www.geocities.com/id_ivan/
id_ivan is offline
Old January 28th, 2007   #13 (permalink)
Name: David Barbarash
Also, I would recommend importing the CAD file into Illustrator as a PDF, otherwise (in my experience) you won't get your proper lineweights. Though then again, I'm still working with archaic color pen settings... maybe if I moved to object settings it would fix it.
DaveMBarb is offline
Old January 28th, 2007   #14 (permalink)
phix95's Avatar
Thanks for the tip.
phix95 is offline
Deadline - KRob Architectural Drawing Competition johnmcclennyhale General Discussions 0 October 23rd, 2006 12:52 PM
What is the most important skill for architectural visualization? Alison K. Rathbun General Discussions 32 May 16th, 2006 05:02 PM
Professional Architectural Visualization ubersubtle General Discussions 36 March 10th, 2006 01:22 AM
A few questions for you Architectural visualisers Notorious General Discussions 13 February 18th, 2005 06:02 AM
A few basic questions re dual processors Michael Earley Hardware and Technical Discusions 1 April 28th, 2004 03:16 PM
