Old January 23rd, 2007   #1 (permalink)
Default vray material
Hey,
I am trying to render a window with glass. I finally got a pretty good glass setting but when I render it in passes and comp it, the colour RGB channel is very faint and can hardly be seen.
Anybody have any suggestions?
Another issue, is there any way of rendering all the reflections in one render, in other words not using the frame buffer/passes?
lefks is offline
Old January 23rd, 2007   #2 (permalink)
Timothy Saunders's Avatar
Default Re: vray material
As part of both questions: Are you using Vray 1.5? If so, I don't see "RGB" as an element to render.
Timothy Saunders is offline
Old January 23rd, 2007   #3 (permalink)
I am using Vray 1.46...Sorry what I mean is, when it renders all the passes...It creates the main one which is the colour pass, and then the alpha, plus whatever else you have selected. The main render window looks good but when the image is saved its faint..Not sure if I've explained myself properly
thanks
lefks is offline
Using merged model's Vray materials in your current Material Editor estyl VRay Render 2 January 16th, 2007 08:04 PM
Vray material problems in vray free ssstrutz VRay Render 6 September 14th, 2006 01:06 PM
vray material over bright warning aligrafix VRay Render 0 August 24th, 2006 01:40 AM
Vray Material Library yogeshwagh VRay Render 12 June 17th, 2006 11:57 PM
vray material proces2 VRay Render 11 July 9th, 2003 10:24 PM
