Thread: Slice Script
Old July 14th, 2008   #1 (permalink)
Bewdy
Bewdy's Avatar
Default Slice Script
Hi, I'm looking for a script which will automate a process which I seem to do a lot of.
I'm often having to double slice poly's at very regular intervals, (so that I can extrude the double sliced polys) usually for modeling mortar joints, creating tile patterns, brick coursing that sort of thing.
I'm guessing there must be a script for this somewhere, I've had a quick look on some script sites, but I thought I'd ask here, as someone may be doing exactly this sort of things as well.
Ideally, I'd like to be able to set two different slice offsets, (or a single slice offset and the distance of the second slice from the first) and a count for the number of slices across the object.
Failing that, is there a function in Max to record an action, and then play it back so one button will do multiple functions, much the same as the way photoshop does?
Cheers for any help.
Matt Sugden
Business http://www.virtual-living.co.uk
Pleasure http://www.icompositions.com/artists/OnIt
Bewdy is offline   Reply With Quote
