Cinema 4D Cinema 4D
Old January 24th, 2007   #1 (permalink)
guitarboy's Avatar
Australia  Send a message via MSN to guitarboy
Default Help with importing a .3ds file into cinema 4d
G'day all, im new to cinema, and need help getting my .3ds file to import into cinema. i tried using the merga method and i only got half my model for some reason. is there another way to get my model to come in correctly???
many thanks.
guitarboy is offline
Old January 24th, 2007   #2 (permalink)
AJLynn's Avatar
Default Re: Help with importing a .3ds file into cinema 4d
Use File menu - Open and choose the 3DS file.
AJLynn is offline
Old January 28th, 2007   #3 (permalink)
guitarboy's Avatar
Oh, thanks. i was looking for the more difficult option straight up. i tried it this way tho and still only the ground floor and part of the first floor have come in, im still missing the top 3 levels. any one have any ideas as to why this is happening? im also only running the demo version which might be causing this problem, i think it might have be ready to expire.
Old January 28th, 2007   #4 (permalink)
STRAT's Avatar
Wales
where are you importing your 3ds from? what is in your 3ds file - 3ds content is only 3d stuff, any 2d drawing is ignored. you might also find that exploding your model before you make a 3ds file out of it to export is a better option too in some instances. Also, huge meshes need to be broken down into a few different objects before you 3ds them.
STRAT is online now
need help importing a file into 3d max dnaranjo 3ds Max 3 April 26th, 2006 08:07 PM
Question about importing dwg file edward80 3ds Max 4 June 24th, 2005 09:26 AM
AUTOCAD dwg file convert to PDF file Chris Potts AutoCAD/AutoCAD Architecture 9 October 8th, 2004 01:42 AM
Problem while opening 3D max file into Cinema 4D manepalli General Discussions 3 August 23rd, 2004 12:40 AM
export archicad file to .3ds? angelo_anim Archicad 4 October 19th, 2003 01:36 AM
