Old January 25th, 2007   #1 (permalink)
India  Send a message via Yahoo to sachinwalvekar
Default Need help in vray to sharpen interior image
hi,
I am using 3dsmax8 & vray 1.5 rc2 for the interior living & finding parts of the render getting blur. Would like suggestions to sharpen the image. I have kept the present to medium & tried custom changing setting which affect sharpness (nrm thresh : 0.1). My settings for vray are :
primary : irradiance map
sec : light cache
irradiance map settings:
currrent present : Medium
hsph subdivs: 50
interp samples : 20
nrm thresh : 0.1
Detail enhancement: on
scale : screen
radius : 60
sub divs mult 0.3
Light cache settings:
subdivs: 50
sample size : 0.02
Please let me know if there any settings that I need to change to get sharper images.
Your comments & critique for the image is welcome.
sachin.
sachinwalvekar is offline
Old January 25th, 2007   #2 (permalink)
Trevor Tizard's Avatar
England
Default Re: Need help in vray to sharpen interior image
First you need to change the irradience map settings to high and see if that does the trick before customising the medium settings.
The curtain colour bleeding is correct, however you can use the Vray Override material to get rid of it.
Lastly there should be some shadow cast from the table even though is is glass.
Trevor Tizard is offline
Old January 25th, 2007   #3 (permalink)
manta's Avatar
Here read this...
http://www.cgarchitect.com/news/newsfeed.asp?nid=3524
Go down to : Critical V-Ray Settings – Part I
its PDF file very informative...
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old January 25th, 2007   #4 (permalink)
erickdt's Avatar
Name: erick gustafson
Your lightcache subdivision settings are crazy low! I usually have it set to subdivisions @ 1000 and sample size @ 0.02 for final renders. For test renders I ramp it down to subdivisions @ 500 and sample size @ 0.2.
Hope that helps!
erickdt is offline
Old January 25th, 2007   #5 (permalink)
Brian Smith's Avatar
with the IR map settings you have, this is totally an AA issue...i'm guessing that your using the deffault Adapt Subdiv with the default -1,2 values...that's not going to do it here. Try QMC 2,5...and work up from there.
Detail enhancement will do nothing for you if you don't have AA set right. I would get rid of it and use as a last resort...it can really, really, add rendering time. It will also do nothing if you dont have enough IR Map samples (which is not a problem here)
As Erick stated, your light cache is really low (though that has zero to do with your problem)....a subdivs value of 1000 shouldnt take long at all with this kind of scene
You can tone down that color bleeding by right clicking > VRay properties, and changing the Generate GI from 1.0 to something smaller, like 0.5
BTW...what kind of camera are you using and what kind of settings...the image looks a little distorted.
Brian Smith
www.3dats.com
Brian Smith is offline
Old January 25th, 2007   #6 (permalink)
actually i used the wrong term...it's not an antialiasing issue, it's an image sampling issue
Brian Smith
www.3dats.com
Old January 26th, 2007   #7 (permalink)
hi,
Thanks Brian smith, ericdt, manta, Trevor Tizard for your suggestions. I highly appriciate time u spent in answering.
I have started experimenting with suggested settings & there has been marked improvement, but have yet to master it. The roof part shows noise.
Here is the latest rendering with light cache set to 500. I was just trying to keep render time less by having a lower light cache.
I have used 3d studio camera with 15 mm lens. This was to match the clients required view angle. Attached is the clients view along with the current.
Thanks all of u for your timely help.
regards,
sachin.
Old March 28th, 2007   #8 (permalink)
andreg's Avatar
Canada  Send a message via MSN to andreg
It's getting there dude
My comments are that some things seem to be off scale, like the chair... the seat is lower than the coffee table and the lamps seem kinda small.
Anyway check that out, good start my friend
andreg is offline
Old April 2nd, 2007   #9 (permalink)
where and what is the light source in the scene?
to me it looks like its coming from camera direction. the lamps in your scene need to add light to scene to make it look more interesting. unless its a day scene you want to make and lamps are off, in that case there should be a light source behind the windows and the ceiling and floor should be illuminated near the windows.
good work so far, the hard part is over only a little tweaking with light is required.
good luck mate.
stormchaser is offline
Old April 2nd, 2007   #10 (permalink)
kippu's Avatar
those couches look so tiny and the curtains look like a sheet. good luck with this
www.renderviz.com
kippu is offline
Ten vray questions steve VRay Render 10 September 13th, 2008 10:20 PM
HDR,Vray Sun, Vray Sky, Vray phy: camera mmakilm VRay Render 17 May 24th, 2007 11:12 AM
LWF in vray for an idiot! aflack VRay Render 6 December 19th, 2006 10:11 AM
vray interior help foorked1 Work in Progress (WIP) 5 October 18th, 2006 11:01 PM
Vray and Brizal Rio plug in Chris Potts Other 3rd Party Renderers 7 September 16th, 2004 02:01 AM
