3ds Max Autodesk 3ds Max
Old January 28th, 2007   #1 (permalink)
Default Camera Matching???
What is the easiest way to camera match a new architectural structure into an existing photo? I want to pull some photos off of google and build commercial buildings to place into the photos. How can I get the precise camera angle and lens to match the photo. Thanks.
jophus14 is offline
Old January 28th, 2007   #2 (permalink)
Tommy L's Avatar
Default Re: Camera Matching???
unless you can work out where the camera was in plan, you just have to eyeball it.
Tommy L is offline
Old January 29th, 2007   #3 (permalink)
Should I just use the image as my background then? Is there a way to lock the background so it doesn't move when zooming in and out? What about having the backgorund move up and down with the camera? Thanks
jophus14 is offline
Old January 29th, 2007   #4 (permalink)
martin walker's Avatar
United Kingdom  Send a message via MSN to martin walker
a start would be to presume the photo was taken with a 35 mm camera, this will help with your perspective
Id agree with Tom though, a good eye beats any technical method
martin walker is offline
Old January 29th, 2007   #5 (permalink)
Romania
Cool Re: Camera Matching???
Hi
There are some camera matching utilities but I prefer to use some reference objects which represent terrain and buildings from the surroundings. A good idea is to use a terrain scheme or at least some info about closer objects (buildings, trees, etc.). When you build those objects (just a few) distances and sizes are very important but the mistakes can be easily corrected from perspective. After this I choose my photo as background in viewport and I make the corrections from wireframe view. Using this technique you will be able to use latter Matte/Shadow material to have some realistic shadows even on surroundings. It`s very important to know the type of lenses from the photo or video camera.
Mihai
vizfx is offline
Old January 29th, 2007   #6 (permalink)
England
also try to allign the horrizon / vanishing points in your 3d scene with the photo. the horrizon should be the same on both.
Pikcells Animator, Modelling & Environment Designer
notamondayfan is offline
Old January 29th, 2007   #7 (permalink)
Tommy L's Avatar
Unless you have a site plan and some accurate height references, eyeball it. End of.
Mind you, eyeballing aint easy. And if the photo is your backgroud, whats all this moving up and down its zooming in and out malarky? Background should stay put. One thing is, make sure your render parameters are set to the same aspect ratio as the photo.
Tommy L is offline
Old January 29th, 2007   #8 (permalink)
anvaraziz's Avatar
evermotion have a very good tutorial regarding camera matching.
http://www.evermotion.org/tutorials/compositing/arch/
www.mukks.com
anvaraziz is offline
Old January 30th, 2007   #9 (permalink)
Matt Clementson's Avatar
Name: Matt Clementson
If your image has EXIF information attached to it you may get the lens details from that - remember that you have to correct from a digital lens length to the optical equivalent as well to get the correct settings for your scene.
Matt Clementson is offline
Old January 30th, 2007   #10 (permalink)
Thanks everyone. I tried the Evermotion tutorial a while back with nothing but a headache to show for it. I also tried the tutorial that came with Max/VIZ for the Camera Match option using the microwave and the background, but I still had no luck.
jophus14 is offline
Camera Matching Stills ZFact Cinema 4D 8 April 12th, 2006 03:15 AM
Camera matching question MazenSamir 3ds Max 4 February 20th, 2006 07:40 AM
animation camera matching Bugga_Guy General Discussions 11 April 23rd, 2005 07:51 PM
Camera Matching Frosty Cinema 4D 1 May 25th, 2004 01:05 AM
Canon G5 camera and camera matching pailhead Hardware and Technical Discusions 4 February 24th, 2004 12:08 AM
