Re: 3D max problem
you are very far from the zero point.
i don't know if this has a relation whith your problem, but you should do this thing properly.
center your autocad drawing or export a wblock whith base point near your object. being too far from zero can cause many geometry problems....
you should first clean your autocad drawing, purge it, control it, center it around zero or move your ucs, AND THEN export it.
