Thread: 3D max problem
Old July 18th, 2008   #9 (permalink)
SandmanNinja
SandmanNinja's Avatar
Default Re: 3D max problem
And from an earlier post:
To centre the origin in AutoCAD (preparing to bring it into 3DS):
in autocad, use the 'move' command (M) and when asked to select objects, type 'all' (make sure all layers are on and not frozen/locked)
hit 'enter' and when asked for a base point, select a point in the center of your model (or where ever you want the origin to be).
once you have that, then type in 0,0,0 to move it - this is the origin point in autocad where the intersection of the X/Y/Z axis meet.
-SandmanNinja
website
SandmanNinja is offline   Reply With Quote
