Old January 30th, 2007   #1 (permalink)
Cesar R's Avatar
Default Dual Monitor Color question..
Guys, quick related question,
i just bought a second Dell ultrsharp 20.1 monitor to along with the one I already have (same type) but i noticed that they colors are not the same from monitor to monitor... is that normal?
for instance a "white" document looks pretty white on one screen and when transfered to the "new" screen it has a tint of yellow/red.
Im just wondering how to fix that or if there is something wrong with my second "new" screen - which is the one that shows yellowish
Im using them both on a single graphics card ATI each connected to its own DVI output.
Xeon 5130 : Revit + 3DSMax
Fa5 - Honda Civic Si
Cesar R is offline
Old January 30th, 2007   #2 (permalink)
Name: Matt McElhiney
Default Re: Dual Monitor Color question..
First off, every display device is different and will display color differently even when the settings are the same. What you need to do to get them as close as possible is:
First: calibrate each monitor individually as the single primary display using some calibration tool. There are some cheap ones out there...Eye-One, Spyder2 etc.. if you don't want to spend a bunch. This will give you a color profile for each monitor.
Second: You need to set up your OS to recognize the color profiles and use them... how to do this can very obviously depending on your OS. A google search for your OS and setting up color profiles should help out.
A side note that I found ~ If you are using an AGP dualhead card under Windows XP, you would need to download a Color Control Panel utility from Microsoft. If you are using an PCIe card then you can already assign the profiles to each device separately and do not need the utility.
Once both monitors have been calibrated then you should see very similar color but it will never be perfect... hope this helps somewhat
NeonMojo is offline
Old January 30th, 2007   #3 (permalink)
Cesar R's Avatar
great i was starting to think my monitors were deffective. thanks !!
Cesar R is offline
Old January 31st, 2007   #4 (permalink)
Matt Clementson's Avatar
Name: Matt Clementson
It could be that the colour temperatures are set differently on the two monitors - causing one to look more red/orange than the other.
Matt Clementson is offline
Old January 31st, 2007   #5 (permalink)
Cesar R's Avatar
would you know how to change that in a DELL ultrasharp?
Cesar R is offline
Old January 31st, 2007   #6 (permalink)
Cesar R's Avatar
I played a little bit w/ the RGB values of my screen and it seems it made a little better.. thanks,
Cesar R is offline
Dual processor - Dual Core + max tommyjj Hardware and Technical Discusions 10 June 27th, 2006 11:28 AM
Pentium 4 Dual processor or Xeon Dual processor aligrafix Hardware and Technical Discusions 16 April 17th, 2006 06:15 AM
What to do to improve?? ryandi Hardware and Technical Discusions 12 April 4th, 2006 03:00 PM
dual processor to dual core pavement Hardware and Technical Discusions 18 February 11th, 2006 03:28 AM
Dual 1.8 g5 or dual xeon????? Esteban Gonzalez Hardware and Technical Discusions 5 December 7th, 2004 11:57 PM
