Old January 30th, 2007   #1 (permalink)
Default Glossy Reflection
Hey Guys,
I have been using glossy reflections on a ceramic sink that I have been working on. Render times are quite high but I have tweaked the scene to bring them down a little. My question is, is there any other way to get the sink look glossy without using glossy reflections? I could fake the reflection on the sink but it would not give me realistic results. I want to know of another technique maybe that I could apply to all glossy objects not necessarily only a sink!!
thanks
lefks is offline
Old January 30th, 2007   #2 (permalink)
manta's Avatar
Default Re: Glossy Reflection
Well you could go into "options" on that material and uncheck trace reflections, or you might try using an hdri in the reflection...
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old January 30th, 2007   #3 (permalink)
thanks Manta,
wouldn't unchecking trace reflections make my reflections disappear?
lefks is offline
Old January 30th, 2007   #4 (permalink)
Timothy Saunders's Avatar
Yes and no. Unchecking trace reflections will cause only the light to be "reflected". It is the method I use a lot for far away small metal surfaces, like a window frame, or metal tubing. It just gives you a specular hilight, but ceramic needs an actual reflection, not just a hilight. There may be other ways to fake it by playing around with the falloff map. How blurry would the reflections really be in a ceramic sink? I wouldn't think you would go any lower than .85.
Timothy Saunders is offline
Old January 30th, 2007   #5 (permalink)
thanks for the info! I think my setting is at 1.0 for glossiness right now..I tried to reduce it even a little but I think because of the camera angle it won't even show any "gloss" if I lower it. I am assuming its my camera angle...
lefks is offline
Old January 30th, 2007   #6 (permalink)
nicnic's Avatar
you wont get any glossy effects on 1 unless you unlink the highlight glossiness and change it to something like .85 or .9
nicnic is offline
Old January 31st, 2007   #7 (permalink)
I actually have my highlight glossy set yo 0.1 and my refl. glossy to 1 (unlinked) and it gives me a nice glossy sink...I was just curious about an alternative!!
lefks is offline
Old January 31st, 2007   #8 (permalink)
Brian Smith's Avatar
Have you tried interpolation...it can really help with the rendering times but make sure that if you use the irradiance map, that you match the Min/Max rate in the reflection interpolation rollout with the Min/Max rate in the irradiance map rollout. The lower your Reflection Glossiness value, the more the interpolation can be of benefit
Brian Smith
www.3dats.com
Brian Smith is offline
Old January 31st, 2007   #9 (permalink)
Tommy L's Avatar
A solution that can be very effective, but is scene specific, is creating an environment map for the object using the panorama exporter. Its a cheat and not 100% accurate, but it fools the eye and renders in no time:
1 turn off your shiny object and place a camera there instead.
2 (utilities) panorama exporter.
3 use the paniramic in the environment slot of the shiny object
4 exclude shiny object from recieving reflections.
5 render.
With a few tries you may get some good results. Its quick to render because instead of calculating geometric reflections its just creating a reflection from a bitmap.
Tommy L is offline
Old February 1st, 2007   #10 (permalink)
thanks Tommy,
I will try that as well!!!
lefks is offline
save the glossy reflection ? designerdisaster VRay Render 5 January 3rd, 2007 02:28 AM
Vray light reflection problem? Piolit VRay Render 2 October 27th, 2006 11:57 AM
Noise reflection of blurry reflection purnomo_adi VRay Render 4 May 24th, 2006 05:47 AM
Floor reflection....again Chris Linek Autodesk VIZ 4 October 21st, 2004 08:51 PM
vray: no gi with reflection virses VRay Render 6 October 8th, 2004 09:25 AM
