3ds Max Autodesk 3ds Max
Old January 31st, 2007   #1 (permalink)
DsgnVsualization's Avatar
United_States  Send a message via AIM to DsgnVsualization
Default Best way to model a house in Max?
Hi,
I have read alot of diffrent ways to model walls , Parametric Programs and import it, AEC walls in Max or splines etc.. what is the cleanest and most accurate way ? Appreciate any advice
DsgnVsualization is offline
Old February 1st, 2007   #2 (permalink)
sterealkey's Avatar
Name: Piet de Wet
South Africa  Send a message via MSN to sterealkey Send a message via Skype™ to sterealkey
Default Re: Best way to model a house in Max?
Personally I do it with splines.
A single line, then make it renderable and visible in viewport, set it to rectangular and give it the required height and thickness. This I find quite easy to work with while I'm still trying to get the basic building in proportion.
Then when its all good I convert it to editable poly and start booleaning my windows & doors.
Any other views out there?
www.ocellus.co.za - innovation in design, illustration and visualization
sterealkey is offline
Old February 1st, 2007   #3 (permalink)
Check this out right here on this site:
http://www.cgarchitect.com/resources...tutorial13.asp
Ismael is offline
Old February 1st, 2007   #4 (permalink)
Check this out there are loads of tutorials on how to create a house in max by Ted Boardman.
http://www.tbmax.net/
www.resolutiondigital.co.uk
Renato1 is offline
Old February 1st, 2007   #5 (permalink)
England
or jus learn to box model, none of this boolean bull!!
Pikcells Animator, Modelling & Environment Designer
notamondayfan is offline
Old February 1st, 2007   #6 (permalink)
2 thoughts...
1) are you using any other software to create plans? If so....
1A)you can model some of it there
1B) Draw the plan in CAD with polylines and extrude them in Max
1C) import the plan and "trace" the plan with lines. Extrude away! And Box model everything else.
2) Box model a basic massing....i.e build only a general mass..like a clay model. Once you have that, and you like it, then start building the walls and such. Try to stay away from too much detail. Use materials to do some of that work for you.
PLEASE, try to stay away from boolean. It is WAY more trouble than it is worth. Learn to box model and find the Slice modifier.
studio2s is offline
Old February 2nd, 2007   #7 (permalink)
We model buildings all day long and weve found the best way is to start with a corner stone. So draw a rectangle 30 x 30 and extrude to give a thickness of 5 this represents the corner of the building.select a polygon face in the direction you want to go(not the upper nor the under) and extrude the face along to a window, extrude again for the window width,extrude for the wall width,window ,door,wall whatever and complete a whole periphery. when thats complete select all the upper face polygons except those over the windows and doors and extrude up say 215 a door height and then again 55 for a lintol height, where you havent extruded will be your openings.Its quicker with a dwg plan imported as a frozen template to guide your extrusions.Hope that helps
BrianLake is offline
Old May 6th, 2007   #8 (permalink)
Onzki's Avatar
Philippines
HI BRIAN LAKE..
on my case i usually start with cad for 2d & merge the file(layer only) to max for modeling... However I'm still seeking other ways to create model "purely" from max/viz--and I'm just curious & interested about your procedure.. do you have any short vid clip OR screenshots (with caption) for this? hope you can share it here or email me at arkionzki@gmail.com
thank you!
Onzki is offline
Old May 6th, 2007   #9 (permalink)
mskin's Avatar
Name: herbert mellville
what about actually drawing the elevations, extruding them and then rotating them into position?
mskin is offline
Old May 7th, 2007   #10 (permalink)
only3d's Avatar
Israel
the best way to model a house in max is......... not in max!
i use archicad personally, revit, ADT or even sketchup will do.
good luck
only3d is offline
Revit To Max, Why Such A Nightmare?? Jefferson Grigsby AutoCAD/AutoCAD Architecture 2 August 5th, 2006 12:28 PM
exporting into Max Jefferson Grigsby Autodesk Revit 2 August 5th, 2006 08:43 AM
Max model is unnecessarily huge Noise 3ds Max 10 December 8th, 2005 04:15 AM
CAD to MAX raterry 3ds Max 2 December 7th, 2005 09:51 AM
