Old August 4th, 2008   #4 (permalink)
Brute Guy
Brute Guy's Avatar
Default Re: Lack of shadows on HDRI render
Hi,
Thanks for both your feedbacks, to answer your question Nic, I drop my HDRI files into a slot into my material library, then drag this slot into the GI environment tab (one in light source and one in reflections). As far I am aware, the plane is just assigned with a vray white material, no reflection, just white in the diffuse slot. I shall try the HDRi dome technique.
Darius, how do you align the light with the light source in the HDRI, do you do it by eye or is there a way you can see the hdri in the scene?
Marc
Brute Guy is offline   Reply With Quote
