Name: matthew burke |
Sketch and toon for 3D max?
Please could any one enlighten me as to weather or not there is a add on or plug in for 3D Max that dose the same thing or similar as the sketch and toon addon for cinema 4d? Cheers Matt. |
I've used both Cinema and Max for this. For Max, there's nothing as good as Sketch&Toon. The included mental ray contour system and Ink&Paint shaders are usually passable for the linework, but Final Toon is much better in terms of the control you get. For shading, I've done some by using basically every trick I could come up with for NPR styling - reflections combined with Output shaders combined with ambient occlusion and a separate shadow pass with comping in Photoshop and grain filters applied to the shading but not the linework biased toward the dark stuff, etc. (I wish I could show you examples but they were for private projects.) You need to use your own style to pull it off well because there's nothing that does it for you. You can also Final Toon over a GI render but you need to keep it from getting photorealistic.
Name: Jim Buchanan |
You could consider exporting from max into Sketchup6 and using the new styles options: http://www.sketchup.com/?sid=487
I've also seen, but never tried, a plugin called Pencil+ 2 from a Japanese company that does toon style renderings for around $300. If I remember right, there was also a seperate soft style NPR plugin from them too.
...found it: http://www.psoft.co.jp/en/product/pencil/index.html Again, I've never tried it, but it looked good. |
| C4D's Sketch & Toon | pauldoherty | General Discussions | 5 | December 29th, 2005 12:32 PM |
| Sketch n Toon Question | dazz_downunder | Cinema 4D | 0 | November 9th, 2004 03:29 AM |
| CINEMA 4D R8.5 AND SKETCH & TOON SHADER | STRAT | Cinema 4D | 10 | November 25th, 2003 06:16 PM |
| Sketch or Toon Renderer? | Munz | Autodesk VIZ | 7 | February 12th, 2003 07:22 AM |
