Old February 14th, 2007   #11 (permalink)
antonio_frias's Avatar
Name: Anthony Miguel De Frias
France  Send a message via MSN to antonio_frias
Default Re: V-ray error:cannot create bitmap
Thx, this worked out nicely!
Originally Posted by mr. a View Post
It sucks! I believe it is an issue of not having enough memory. I ended up finding this somewhere in the Chaos Forum and it worked for me (but personally find it a pain):
PHP Code:
Basicallyyou are running out of RAMOne way to reduce the memory usage for the render elements is to write the image to a .vrimg file and then use the vrimg2exr converter to extract the channels
Make sure you are using the V-Ray VFB
In the Common tab of the Render scene dialog set the resolution to something like 320x240
In the V-Ray VFB settingsturn OFF the "Get resolution from Max" option for the VFB, and specify the actual resolution that you need
Turn off the "use memory frame buffer" option
Turn on the "write raw image file" option and specify a .vrimg file in the field below it
Turn on the "generate preview" option
After the rendering is complete, use the vrimg2exr tool to extract the render elements as .exr filesYou can find the vrimg2exr tool in the Start menu Programs Chaos Group V-Ray for 3dsmax ToolsThere is also a GUI for it posted in the off-topic section of the forumI think
Alternativelyyou can simply render on a 64-bit machine with 64-bit 3dsmax and V-Ray
Best regards
Vlado
I am still quite ticked that with a new machine and Windows XP I can't render an image at 2400 x 3600 px! Apparently, with Windows 64bit you are not limited by memory.
Someone out there correct me if I am misunderstanding things.
antonio_frias is offline
ERROR MESSAGE: Cannot create bitmap antonio_frias 3ds Max 2 February 27th, 2006 03:47 PM
Max 7 Lights with Mental Ray OllyNicholson 3ds Max 9 July 21st, 2005 01:13 PM
mentay ray exterior rendering (unchallenge) Sirkus The Unchallenge 47 August 22nd, 2004 03:10 AM
maxscript - create face from bitmap Gleggers Scripts 2 April 2nd, 2004 04:51 AM
