| 3ds Max Autodesk 3ds Max |
Name: Vincenzo Crupi |
Hi Everyone,
I imported floorplans and elevations done in CAD into 3ds max 9. The files range from 65kb to 542kb (small files), there are about 14 files I imported. No hatching or x-refs were selected in the options when importing into max. So here's my question... If all these files are so small, then why is my max file 68mb? I haven't even started the project yet and this file is huge. Anyone have answers for this? Thanks in advance. |
My guess is that every single line is treated as an object. If you check the Summary Info you'll see you have thousands of lines/objects, hence the size of the file. What I do is use the lines and delete them afterwards. But, again, I ain't no expert, so I might be wrong.
Name: Justin Hunt |
If you are just using the CAD files to model off then use the file link manager. Makes it really easy to update the CAD files, and get rid of them when not needed any more.
JHV |
Name: Brian Smith |
it's the same reason that a teapot with 64 segments is only a few kb but when collapsed is over 10MB...i dont know what the scene looks like but it's not hard to imagine 14 files of that size can equate to that file size in max. importing lines from dwg, dxf etc is quite a chore....can take several minutes to import an average size drawing. it's what i call a dirty cad file...i recommend cleaning house
| Importing CAD models into 3ds Max 7 | bover | 3ds Max | 1 | October 10th, 2005 10:51 PM |
| Cant open 3ds max 7 files in Viz 2005 | Verma | Autodesk VIZ | 8 | January 27th, 2005 05:30 PM |
| Importing .dwg files into 3ds max 4.0? | omd1 | General Discussions | 2 | October 5th, 2004 09:10 AM |
| 3ds MAX and W2K SP 4/Hot Fix Issues | Jeff Mottle | 3ds Max | 16 | October 10th, 2003 12:07 PM |
