Name: Sumit Devgun |
hi all.. I am using max 9 with vray rc3, & facing a problem in renering. whenever i render my scene, vray light is visible in reflections ( like mirror or reflection in floor or wood etc. ). although it is not visible in camera as i've turn on invisible option. pls help...
thanks in advance... |
in your material settings, for your glass, scroll down your tabs and there should be a option tab, (im refer to the tabs that say maps, etc). within the option tab there should be a tick box with something like traced reflections. tick/untick that. im only very new to max/vray too, but thats where i found it, im using an older version tho, but if you cant find it, let me know and ill try to explain it better.
Thanks. But if turn off trace reflections, then it'll turn off all the reflection.. But I want to turn off the reflection of vray lights. not of the other objects.
any other option???.. |
Guys I did some tests trying to analyse your problem.
I noticed when I switched on the 'skylight portal' checkbox in the vray light options, then it fixes the problem. Dont know if it has any other side effects though Would still like to get someone else's view on this. What does skylight portal mean, and why does this fix it?
www.ocellus.co.za - innovation in design, illustration and visualization |
| Tips for boosting Vray rendering | estyl | VRay Render | 10 | May 6th, 2008 09:31 AM |
| Vray rc3 & max9 network rendering prob | philip kelly | VRay Render | 4 | October 31st, 2006 10:09 AM |
| rendering animation seqence on the networ with vray | maxkid | VRay Render | 3 | October 18th, 2006 04:24 PM |
| vray rendering animation with backburner keeps rendering 1st frame | d7man2000 | VRay Render | 3 | February 21st, 2006 02:02 PM |
| vray light problems...please help!!!! | ecastillor | VRay Render | 2 | July 25th, 2005 05:53 AM |
