| 3ds Max Autodesk 3ds Max |
Name: Jozef Zajac |
Hi,
I have decided to post this topic to get deeper into the rendering part ... and share experiences about viewport performance I made quite nice optimalization for vieport performance on my HW athlon 1,7Ghz, 768 RAM, ATI Radeon 9600 XT 128MB I started up with an Interior scene with 16.ooo triangles on 24 fps in viewport and ending up with 135 fps ... rising the performance over 5x A was also getting realtime performance displaying 1. million triangles from another scene ... keeping these things on mind
Thanx a lot Zajo Last edited by zajooo; February 26th, 2007 at 04:27 AM. |
Name: Dean Punchard |
another tip to speed up viewport viewing - if you have any mesh smooths or turbo smooths, right click the light bulb in your modifier stack and click "off in viewport". this will only turn on the smooth at render time. works for other modifiers too.
Pikcells Animator, Modelling & Environment Designer |
I also used to try all sorts of things to make my viewport navigation a bit smoother.
I dont know what they changed in Max 9, but scenes that used to give me a headache in Max 8 I can now open in Max 9 and navigate around them like Superman on Red Bull. I didnt change any hardware, just software. Whatever they did, it impressed me.
www.ocellus.co.za - innovation in design, illustration and visualization |
#5 (permalink) | |
Name: Jozef Zajac |
Lets take a better look on the scenes ... Both scenes have 2.176.566 triangles1) the first scene has 13.585 objects 2) the second is the same scene optimized for viewport and has 70 objects Lets see the first VRay basic settings rendering statistics of 1)
2) Rendering time: 11 min and 36 sec. actualy after rendering I have realized that one of the matterial is not the same so I have decided to override the material to eliminate the influence of the materials ... I used the standard VRay material ... and the rendering time 1) 5 min. and 50 sec. 2) 5 min. and 47 sec. Leading to over 63% redering time savings and one more test before some conclutions I have changed the VRay material to Max standard material and tested on the first scene 1) getting the result 11 min. and 51 sec. Conclusions: After rendering the normal scene and viewport optimalized scene ... I predict and conclude
Wow
I'm so pleased that someone actually took the time to do this experiment. Its something thats been on my mind for quite a long time. Thanx Zajooo! At least now we know its not worth spending time on simplifying your scene, coz it only saves you 3 seconds at the end of the day
Name: Jozef Zajac |
... so lets continue
Another test scene, 16.ooo triangle, an interior of a shop, render res. 800x600 proving the qualities of VRayMtl, for rendering in VRay. using default max materials 161 sec. converting materials to VrayMtl 72 sec. the render lead to 56% time saving. Well at the end of the week I made some upgrade of my computer ... I have added extra 1GB of memory (leading to 1,5GB), and I was quite surprised with the rendertime downswing. The test scene was as in previous post a building of about 2 mil. triangles, using XRef for details, at resolution 4000x3000, VRay renderer. The rendering time was about 4 hour before upgrade. After the upgrade, and merging the XRef scene into one file (this was posible without caching thanx to the extra memory) ... I have achieved rendertime less than 1 hour, leading to 75% time savings Afterwards I have took all od the objects and made 2 VRay proxies out of it. The test render using VRay proxies took 2 hours. The both renders using proxies and loaded geometry have taken 1,08GB of memory. And I could not figure out why. Everybody talks about saving memory using VRay proxies, how does this work? Does enybody have som explanation? Does the Proxies start to workout when getting over the memory limits for a scene??? Last edited by zajooo; February 26th, 2007 at 04:16 AM. |
| Price of V-Ray Stand Alone Version? | GaryR50 | VRay Render | 45 | April 2nd, 2008 11:57 PM |
| NEWS: ARTVPS Launch new Rendering Solution with Mental Images | Jeff Mottle | SIGGRAPH 2006 | 0 | August 1st, 2006 10:41 PM |
| HELP! errors in rendering complex scene | notamondayfan | VRay Render | 5 | April 21st, 2006 03:07 AM |
| Rendering a photo within my scene problem | jamiebyers | 3ds Max | 3 | March 29th, 2005 06:48 PM |
| Rendering a scene with video post | Jordy | 3ds Max | 2 | December 2nd, 2004 07:11 PM |
