3ds Max Autodesk 3ds Max
Old March 1st, 2007   #1 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
Default Max9 & MR: Rendering: How to setup the Bitmap Pager and is it slave- or file-based?
Hi All,
I try to render a large image, but I always got 99.99% of the render done when the system hangs.
I'm trying to save more memory by adjusting the bitmap pager,
but I got no idea how to set it up, meaning I have only this information:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5581641&linkID=5573345
I would also like to know whether the setting of the bitmap pager is 'slave'-dependent or 'file'-dependent,
meaning: do I have to setup the bitmap pager on a per slave/machine basis? or do I just set it up on my workstation?
rgds,
nisus
nisus is offline
Old March 1st, 2007   #2 (permalink)
martincg's Avatar
Name: martin prochazka
Slovakia
Default Re: Rendering: How to setup the Bitmap Pager and is it slave- or file-based?
Hi, what kind of render do you using?
martincg is offline
Old March 1st, 2007   #3 (permalink)
nisus's Avatar
Belgium
MR3.5 (in max9)
nisus
nisus is offline
Old March 1st, 2007   #4 (permalink)
martincg's Avatar
Slovakia
Default Re: Max9 & MR: Rendering: How to setup the Bitmap Pager and is it slave- or file-base
hm...i am using v-ray so no much help with MR. but sometimes in vray helps, if i am using batchrender /memory saving too/, export it to .bat file, close max and just start directly from .bat file. /sorry for previous Q, did not read the head line/
martincg is offline
Old March 1st, 2007   #5 (permalink)
nisus's Avatar
Belgium
Hi,
That's why I use networkrendering. It's a bit the same...
don't worry. I edited the title AFTER your Q. I was not specific enough myself ,-) Tnx for pointing that out.
rgds,
nisus
nisus is offline
