Old March 8th, 2007   #1 (permalink)
Default Vray animation resolution
I am rendering an animation 720 x 480 for DVD. I am having real difficulty getting a good resolution - the client is telling me it is too blurry. If I render it with more detail it starts to look artificial. I am rendering it in the "medium-animation" setting and have already rendered out a LC and IR map.
I believe the problem is that you can't pack smaller pixels into a frame this size, therefore you can't get good detail until you are rendering out to a larger size frame. Is that what you would do, then resize it in combustion or after effects.
Thanks in advance for some suggestions.
ipxstudios is offline
Old March 8th, 2007   #2 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
Default Re: Vray animation resolution
are you showing him still frames of the animation for approval?
...or, how are you showing him the piece for approval? ...some codec blur images more than others. i remember experimenting with an mpeg2 codec for playback off of my harddrive. it was blurry.
travis schmiesing
crazy homeless guy is offline
Old March 8th, 2007   #3 (permalink)
I sent a fifteen second animation (individual frames) - which looked fine on my screen but they ran it through after effects to put it together and they said it came out rather blurry. It looked kind of pixelated on my screen too - but I wasn't getting any flickering. Any ideas?
Old March 8th, 2007   #4 (permalink)
Chad Warner's Avatar
If they put it through after effects, then it sounds like a compression problem on their end, and not a problem with the frames.
Chad Warner is offline
Old March 8th, 2007   #5 (permalink)
Brian Smith's Avatar
It all comes down to image sampling and antialiasing. The only thing you can do to increase the sharpness without increasing side effects like flickering and pixel dancing is to render high and convert down. It's basically like supersampling. If you render twice the resolution and convert down, you will notice a drastic difference in sharpness. The area filter when scaled down might look like almost as sharp the catmull-rom filter.
Brian Smith
www.3dats.com
Brian Smith is offline
Old March 8th, 2007   #6 (permalink)
nicnic's Avatar
Is this something you do in practice Brian?
If I ahve the time next animation im going to try it out.
nicnic is offline
Old March 9th, 2007   #7 (permalink)
Brian;
Would you increase the frame sizes for the animation then decrease the size to 720 x 480 in post? I thought that might work but then it would increase render times too.
Old March 9th, 2007   #8 (permalink)
yes i do it all the time...though the output size varies depending on the time and computers we have available. we try to shoot for twice the resolution ie, 1440x972 but really anything higher helps. our video editor scales it down for in final cut though you could quickly and easily do it in video post.
Here's an interesting post that talks about it more. rendering high and converting down is something quite a few people do.
http://www.cgarchitect.com/vb/20849-...nimations.html
Brian Smith
www.3dats.com
Old March 9th, 2007   #9 (permalink)
Fantastic thanks for the tip Brian I'll try it.
Old March 10th, 2007   #10 (permalink)
landrvr1's Avatar
Wait a sec.
If you tested this out on your screen, and the individual frames looked good, than the problem is likely to be your After Effects output settings. Can you post those?
Do you use Premiere? There's no reason to export from After Effects if you don't have to...
In fact, post an image from the sequence as well. Are you outputing as .tif files?
landrvr1 is offline
vray animation.. shikodesign2000 VRay Render 3 December 15th, 2006 07:12 AM
Animation in VRAY flickering? charadesia VRay Render 2 June 3rd, 2006 02:46 AM
Help Vray Animation gods418 Work in Progress (WIP) 14 May 29th, 2006 04:03 AM
vray animation question kamikaze VRay Render 8 December 7th, 2005 01:02 PM
What is the best setting for animation using VRAY? cxdesigner VRay Render 2 July 13th, 2005 01:14 AM
