Go Back   CGarchitect.com > MAIN FORUMS > CGA News
CGA News The Latest News Posted on CGarchitect.com
Old March 14th, 2007   #1 (permalink)
President/Founder
Jeff Mottle's Avatar
Post Luxology Delivers modo 203
Luxology® LLC, an independent technology company developing next-generation 3D content creation software, today announced the immediate availability of modo 203.
Read More...
Jeff Mottle is offline
Old March 16th, 2007   #2 (permalink)
Name: Ryan Spaulding
Default Re: Luxology Delivers modo 203
I hope it's ok to post things like this here....
First review of modo 203. I was blown away by some of the renders. I think it could have promise for arch vis. Now if it only had DWG support...
http://www.subdivisionmodeling.com/r...03/modo203.php
RyanSpaulding is offline
Old March 19th, 2007   #3 (permalink)
IC
IC's Avatar
Scotland
Isn't DXF enough? Too much emphasis is placed on direct Autodesk file links. There are easy workarounds for all 3d apps.
http://iainc.carbonmade.com/
IC is offline
Old March 19th, 2007   #4 (permalink)
wda
wda's Avatar
Name: William Alexander
DXF will probably be the best it will ever have. DWG outside of anything 'AutoDesk' will always have issues. Even so with the overlays the 3D geometry is far from "clean", much unneeded geometry. Well anyway dxf with poly line support makes it really fairly easy in Modo to model up just about anything from scratch and ultra clean-connected. There is no better way to do it with large scene files anyway.
Downloaded 203 on Friday. Was more interested in the faster render times and UV improvements. Been using Modo for ArchViz modeling for over 2 years, it works and keeps getting better. However I'm a bit of a purist when it comes to modeling, a whole pile of unconnected primatives in Max or C4D does not a modeler or effeicient model make, imho.
Wax
wda is offline
Old March 22nd, 2007   #5 (permalink)
Not for me. I've never had success with DXF output...ever. But I use MicroStation to build so I'm not sure if this is MicroStation's issue or what...but I hate DXF.
Old March 22nd, 2007   #6 (permalink)
IC
IC's Avatar
Scotland
I suppose that's fair enough but if you owned arguably the best modeller on the market would you still model in Microstation?
IC is offline
Old March 23rd, 2007   #7 (permalink)
That's only half the battle though. The other half is working with architects who send us DWGs, geo-referenced tif's, and things like that. I need to be able to use DWG. It's a must...especially if I need to move cross-software.
Old March 23rd, 2007   #8 (permalink)
IC
IC's Avatar
Scotland
Hmmmm, it sounds to me like you need..........
http://www.okino.com/conv/conv.htm
IC is offline
Luxology Delivers modo 203 Jeff Mottle CGA News 0 March 14th, 2007 12:01 AM
Luxology Announces The Power of Two Special modo Offer Jeff Mottle CGA News 0 November 9th, 2006 12:00 AM
Luxology Releases modo 202 Jeff Mottle Modo 0 August 9th, 2006 09:56 PM
New Luxology Modo Forum Added Jeff Mottle Modo 4 June 6th, 2006 01:20 AM
modo...Modo...MODO...! wda Suggest a New Forum 18 June 4th, 2006 12:36 AM
