Cinema 4D Cinema 4D
Old March 15th, 2007   #1 (permalink)
Ireland
Default Sketch and toon
Hi;
Anyone know how to get sketch and toon to draw a line
down an intersection.
I have checked the intersection part in the controls.
Try this.... create 2 cubes and pull one half way thru the
other so that one cube is half in and half out of the other.,
Now apply a sketch and toon material and render. Do you
see how the line that intersects does not show.,
any ideas?
ZFact is offline
Old March 15th, 2007   #2 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
Default Re: Sketch and toon
The problem may be that you left the cubes as procedural cubes, and forgot to convert them to regular poly geometry.
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old March 15th, 2007   #3 (permalink)
edub's Avatar
change the objects drop down from "self" to "scene" in the intersections menu under lines in the S&K post effect menu...
edub is offline
Old March 18th, 2007   #4 (permalink)
Ireland
excellent... thanks guys
ZFact is offline
hidden-line sketch & toon export to illustrator edub Cinema 4D 12 March 7th, 2007 07:26 AM
Sketch and toon for 3D max? justintime1 3ds Max 7 February 13th, 2007 09:58 AM
C4D's Sketch & Toon pauldoherty General Discussions 5 December 29th, 2005 12:32 PM
Sketch n Toon Question dazz_downunder Cinema 4D 0 November 9th, 2004 03:29 AM
Sketch or Toon Renderer? Munz Autodesk VIZ 7 February 12th, 2003 07:22 AM
