Go Back   CGarchitect.com > 3D SOFTWARE > 3D Tree & Plant Software and Anything Vegetation
3D Tree & Plant Software and Anything Vegetation Everything you ever wanted to know about or post about 3D trees, plants or vegetation goes in this forum.
Old April 16th, 2007   #1 (permalink)
Default Onyx no proxy
I've jsut bought Onyx Broadleaf and thought i'd give it a test.. I've been using Speed Tree..
comments
1. seems like it's best to use Vray proxies, since i don't have vray so i have to use intances, not to bad about 7 minutes to render this scence..
2. Both SpeedTree and Onyx have very indepth was to alter trees but does anyone here actually "create" or even care to alter inside these programs, i'd just like to go to a libary and pick out a tree and be done...
3. looks like from my test you don't want to get to close to Onyx trees(see tree on the left).
4. any tips anyone can give me on Onyx, i know Brian is working on something.
pipjor is offline
Old April 16th, 2007   #2 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
Default Re: Onyx no proxy
I bought Onxy recently. I play with all the sliders. I'm trying to get a handle on what they do so I can modify trees. As good as the library is, I've had three or four trees recently I wanted to make, and none were directly available. No London Plane?
It would make sense to produce two or three variations of a tree you will use repeatedly in a scene so you can show more variety. Make instances or proxies of them, mix 'em up.
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old April 16th, 2007   #3 (permalink)
BrianKitts's Avatar
I edit the trees about half the time. If I can just drop something in out of the library or pull it from an old model I will. Every now and then when the guys in our landscape dept actually specify a tree by genius specie I will open something as close as I can from the presets and then tweak it to match the desired tree. Normally it's changing leaf types, branch length/density and overall height.
Biggest tip i can give is use to install the onyx treestorm plug-in for max that way you don't have edit trees in the standalone and re-import every time you update the tree. And beyond that use the foliage reduction to drop your polygon count. Drop it way down till the tree looks naked.... then slowly crank it up to find the right balance to poly's vs. foliage density so it looks good.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline
Old July 19th, 2007   #4 (permalink)
i tried onyx tree storm library it's very nice .. but i do not have the max pluging for it .. i made so nice trees and palm with it but i need the pluging for wind effect .. if any one can help please mail me ...
arc_najar@yahoo.com
NAJAR is offline
Old July 19th, 2007   #5 (permalink)
Rick Eloy's Avatar
Simple: buy the 3dsmax plugin.
Rick Eloy
Rick Eloy is offline
Old August 4th, 2007   #6 (permalink)
Ukamti's Avatar
Hi David,
What are you using for the grass? just texture or strandz? Wont have much experinace in it but give a try to xfrog also. Though am not able to import the textures of them in max.
Ukamti is offline
Onyx Vray Proxies John Martin 3D Tree & Plant Software and Anything Vegetation 5 March 28th, 2007 03:46 PM
Onyx Tree article Request SunGlare 3D Tree & Plant Software and Anything Vegetation 1 January 22nd, 2007 11:44 PM
Vray proxy... arkitech2 VRay Render 3 December 9th, 2006 01:42 AM
noise on proxy trees Tommy8 VRay Render 8 November 4th, 2006 09:03 PM
optimize a model...vray proxy??? akzit VRay Render 1 February 17th, 2006 10:25 AM
