Autodesk VIZ Autodesk VIZ
Old April 19th, 2007   #1 (permalink)
Default Missing DLL's / DLO's
Anyone know how to remove dll's / dlo's attached to a file?
I have a Cactus model that when merged into Viz2007 comes up with Missing dll's dialog box and lists ParticleView.dlo as missing... obviously Viz doesn't contain particles.
I can actually merge the file and render it locally on my machine, but the issue is that its part of an animation to be rendered across a farm of machines, from past experience missing DLL's cause errors thro backburner and the animation won't render...
I have sifted thro the geometry and modifier stack to try and find any partical refernces to delete, but none seem to exist, also done the same for materials, also opened the file in max and done the same checks just to double check.
any suggests, links to scripts etc. etc.???
JamesTaylor is offline
Old April 20th, 2007   #2 (permalink)
FlytE's Avatar
Name: Andy Pennington
Scotland
Default Re: Missing DLL's / DLO's
Ive had this before but what it tends to be is either the model was made in max or was made in a different version of viz, in which case it contains references to tools or modifiers that are either dont exist or are incompatible.
"How many polygons does the real world push?"
FlytE is offline
Old April 20th, 2007   #3 (permalink)
Thanks Andy,
i actually managed to sort this out by deleting all references to particals from the file, i had tried this previous to posting but happened to miss one instance that was a long way from the geometry and showed as an editable mesh... A cunning devil that caused me a a few hrs annoyance!
Solved! - Missing dll: inknpaint.dlt - Ink 'n Paint Chris LeBlanc General Discussions 0 January 26th, 2006 08:51 AM
deleting missing dll's JamesTaylor Autodesk VIZ 3 July 21st, 2005 07:04 AM
missing Max6 dll's - how to delete for Viz? CRD Autodesk VIZ 2 December 7th, 2004 06:25 PM
Removing missing XREF Objects bwilson 3ds Max 0 November 2nd, 2004 02:25 PM
Missing DLL Dialog Box Arkitec Autodesk VIZ 4 July 15th, 2004 02:05 PM
