Old April 21st, 2007   #1 (permalink)
Name: Rune Jørgensen
Denmark
Default Maxwell Material expert needed
Hi,
Can someone tell me how to make a high quality material out of this texture: http://www.lusica.dk/walltexture.jpg ? I need to know how to make a diffuse- and bumpmap for it.
Ps: Im using Photoshop CS2
Thanks.
turbo2000 is offline
Old April 21st, 2007   #2 (permalink)
AJLynn's Avatar
Default Re: Maxwell Material expert needed
Diffuse is easy, just use the image. Bump - use color select to mask the yellow and make that white and the grout black. Then blend in a bit of grain, making sure to get the sizing right. Also try making a roughness map.
AJLynn is offline
Old April 21st, 2007   #3 (permalink)
Germany
hi,
you can use the mxed wizard and chose brick or you can start with a brick material from the mxm gallery ( http://mxmgallery.maxwellrender.com/...&mode=0&id=444 ) or the arroway brick-20 from the standart maxwell library and change the textures (diffuse, bump, reflection) - after you have created them in ps...
numerobis is offline
Old April 21st, 2007   #4 (permalink)
Denmark
AJLynn - what do you mean by just use the image and blend it in a bit of grain? And how i make a roughness map?
numerobis - when i use the wizard i need a bump map, and thats what i need to know how to make?
Old April 21st, 2007   #5 (permalink)
Germany
the quickest way for me is to adjust the color, suturation and levels.
- i open the texture in ps
- bump up the contrast a little
- reduce the saturation to 0 to get b/w - don't switch it to greyscale cause mxw don't like it...
- invert the map, cause the brighter seams have to be deeper
- then i adust the histogram and brightness/contrast until i get a usable result (to remove bright spots or shadow lines you can reduce the tonal range)
...the same for the reflection map
you should take a look at some examples... here are very good textures including bump and reflection map: http://www.arroway.de/textures/01/de/index.html
Old April 21st, 2007   #6 (permalink)
AJLynn's Avatar
Right - a Maxwell roughness map is like a glossiness or specular map, inverted, and it probably needs to have its levels adjusted to get it right. Erm, if none of this is making sense, maybe you should stick to presets and wizards for now, while reading up on Photoshop and rendering basics.
AJLynn is offline
Old April 25th, 2007   #7 (permalink)
Denmark
Thank you both very much... i have been experimenting with it, and now my photos look very nice!
Maxwell Render 1.5 Maxer Maxwell Render 205 August 4th, 2007 01:59 PM
Maxwell Render Material Contest Jeff Mottle CGA News 0 December 19th, 2006 12:13 AM
Maxwell Announcement Maxer Maxwell Render 24 March 16th, 2006 02:03 AM
How To Create Flat Mirror Material In Maxwell sachin.ostwal Maxwell Render 2 March 3rd, 2006 03:31 AM
