Old April 30th, 2007   #1 (permalink)
Question Importing dwg error
I'm new to light rendering applications, I've imported my files to viz,no problem. I installed lightscape yesterday and tried to import a AD2007 .dwg, I get a error message. Failed to import. I'm using lightscape 3.2 do I have to save my 2007dwg as an older file. Any thoughts are appreciated.
wbritt is offline
Old April 30th, 2007   #2 (permalink)
Default Re: Importing dwg error
Try with A14 or 2000 version:-)
Beeeee!
del82 is offline
Old April 30th, 2007   #3 (permalink)
I'll have to try saving on another machine. AD2007 doesn't have an option to save that old, back to 2004 or r14lt. At school I had to save back to 2004 then put on another machine, then save back to 2000 and it will open. Quite a process.
wbritt is offline
Old April 30th, 2007   #4 (permalink)
Germany
Export/Import as 3DS should be possible!
Marcus
www.einherzfuerpixel.de
3D Rendering, Animation und Architektur-Visualisierung - Aachen
classix is offline
Old April 30th, 2007   #5 (permalink)
Thanks for your input. When I try to import as a ds it can['t find the file. However, I can save as r14 Lt It will import it, the dialog ask if the size is right, it's not but I say yes, it opens and I can't see it.
wbritt is offline
Old April 30th, 2007   #6 (permalink)
prodham's Avatar
autodesk has a drawing converter for any release called 'trueconvert'
if all you need is an earlier version, that should do it.
i'm a little busy to find you the exact link, but just search autodesk.com
prodham is offline
Old April 30th, 2007   #7 (permalink)
Thanks I thought about the same thing and found a converter named dwgateway. Free download that does the same thing. Thirty more minutes to download. If that doesn't work I'll try the Autodesk version thanks a bunch.
William Britt
Undergraduate
University of Arkansas
Fayetteville Arknasas
wbritt is offline
Old May 2nd, 2007   #8 (permalink)
Switzerland Send a message via ICQ to rpict
as you have viz as well, you could link your dwg to viz, apply the materials (architectural), UV's etc. and then export to lightscape. in the lightscape exporter you can define openings by materials, daylight time, layer creation rules etc.
once you change the geometry in your dwg, you can reload it, and thanks to filelinking all materials and textures are automaticliy reapplied.
-rpict
rpict is offline
Importing DWG to VIZ 2006 flatlander4510 Autodesk VIZ 12 February 24th, 2006 06:15 PM
Error when importing from cad to lightscape, help! Lftofcenter Lightscape 6 July 20th, 2005 07:19 AM
Question about importing dwg file edward80 3ds Max 4 June 24th, 2005 09:26 AM
importing a cad dwg to 3d max 4 grooveulas 3ds Max 6 September 19th, 2004 07:46 AM
Max6: How to get rid of the prefix 'Layer:' in importing dwg HarryG 3ds Max 0 November 30th, 2003 08:16 PM
