Old May 6th, 2007   #1 (permalink)
myriadz's Avatar
Singapore
Default Lightscape Under Vista
Hey guys,
has anyone tried installing lightscape on a Vista Machine yet.. Does it work? or should I just put it off completely?
myriadz is offline
Old May 6th, 2007   #2 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
Default Re: Lightscape Under Vista
Lightscape worked well under W2k, much less well under XP (but it does work, I used it last week). It will probably work under Vista, unless the 'war on OpenGL' causes problems.
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old June 1st, 2007   #3 (permalink)
Taiwan
I did it! it can work and better than XP!!
But,i still don`t use vista cz`CAD2006 is fail at VISTA!
pitt0413 is offline
Old June 1st, 2007   #4 (permalink)
Originally Posted by pitt0413 View Post
Ibetter than XP!!
Why?
Beeeee!
del82 is offline
Old June 5th, 2007   #5 (permalink)
Taiwan
in XP ,lightscape "bump maping" can`t be showed just like following image,but in vist can as usal in win2000.
Maybe my XP has problem,maybe!!
IF your "bump maping" is ok!!
please tell me why!!! please please please
pitt0413 is offline
Old June 5th, 2007   #6 (permalink)
Bump maping with reflections, yes
Can you post this under Vista?
Beeeee!
del82 is offline
Old June 11th, 2007   #7 (permalink)
Taiwan
I restored XP already!
pitt0413 is offline
Old June 30th, 2007   #8 (permalink)
Aruba
just a general question, why would you still use Lightscape when the technology is included into 3dsmax?
Just wondering, because staying with an old technology, seem you guys are missing lots new features.
No Offense intended.
Greg
visualasylum is offline
Old July 1st, 2007   #9 (permalink)
That is a popular myth. The technology was not incorporated into Max. There are similar things, but it is not the same.
Lightscape's use of OpenGL is still the fastest I have ever used. I occasionally open a file in LS to check something, and transfer the model into C4D. Lightscape displays the same data faster.
Lightscape was slow to come to a lighting 'solution', but once it did, that lighting was wired into the model. It could almost pass for real-time GI. Now that processors and graphics cards are 100x faster than when LS was a current product, it can do some amazing things right on your screen just in OpenGL via its vertex-shaded model.
The raytracer in LS was exceptional both in speed and quality. I don't think anyone since has written a better one, or even one as good. That raytracer was used in a preview imager for one version of Viz or Max, I was told once by someone who knew the programs well. The raytracer was the work of one brilliant coder, and a few years ago I asked the head of the Max group and former owner of Lightscape, where that guy ended up working. He went to Pixar.
So on the one hand, Lightscape is dead. On the other, if you happen to still own a copy and can make it run under XP (which it doesn't like very much) then you are in for a treat any time you fire it up. And frustration--its missing a lot of things that you would want, like an 'undo'.
Ernest Burden III
AcmeDigital
Old July 1st, 2007   #10 (permalink)
Aruba
The one I hated about lightscape is the way to model. with the new technology in ADT, the productivity has increased more than 5 fold, to me, going back to lightscape eventhough it may compute things faster, the modeling way, is to me, going back to the cave period.
I'm can understand what you mean, but convincing me to go back to the old way of modeling just to continue using lightscape, is just a definetely no-go for me.
Perhaps you found a shortcut that perhaps you are not sharing? are you modeling a different way, that lightscape accepts? or you never migrated to the new way of modeling?
I am curious.
Kind Regards,
Lightscape Scripts for max molson Scripts 10 July 25th, 2008 05:39 AM
Max for Windows Vista aligrafix 3ds Max 2 May 4th, 2006 04:55 AM
(Old Topic) Lightscape versus XP or ? dbillo Lightscape 27 April 8th, 2005 03:53 PM
VIZ to Lightscape to VIZ salty_dogs Autodesk VIZ 2 January 31st, 2003 04:19 AM
lightscape to be retired stephen gilbert Lightscape 14 December 22nd, 2002 10:11 AM
