Autodesk VIZ Autodesk VIZ
Old March 3rd, 2004   #1 (permalink)
Hey everyone,
I'm on Viz4 and I'm trying to get an object to glow using the lens effect-glow. I've tried to use the material channel, sub-object materials, and use the explicit map channel, but nothing seems to work to get the object to glow. Picking a light will glow, but not a box or any other object.
Any help would be great.
Thanks.
Dan
Dan J is offline
Old March 3rd, 2004   #2 (permalink)
Hello Dan,
I think there is a tutorial at CG;architect by Smoke 3d that may have the answer you're looking for.
http://www.cgarchitect.com/resources...tutorial16.asp
Good luck
M. Steadman
(fact is stranger than fiction)
www.lmdesigns.ca
M. Steadman is offline
Old March 3rd, 2004   #3 (permalink)
M and all,
I should be a little more specific. I'm trying to make an object (not a light source) glow using the "Rendering Effects-Lens Effect-Glow" which should be able to do with a map channel, but I can't seem to get it to work in Viz4.
Thanks.
Dan
Dan J is offline
Old March 4th, 2004   #4 (permalink)
quizzy's Avatar
I think you have to do this by using the object ID channel or G-buffer.
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old March 4th, 2004   #5 (permalink)
Quizzy,
That's what I thought and tried it, but nothing. When I had Max this was an easy thing to do, but in Viz I don't seem to get it to work as it's noted in the "help" files. A tutorial would great, if anyone knows of one for Viz.
Dan J is offline
Old March 4th, 2004   #6 (permalink)
have you made the element you want to glow a seperate ID and assigned it in the effects rollout ?
siliconbauhaus is offline
Old March 4th, 2004   #7 (permalink)
Here is an screen image of what I have setup.
http://www.cgarchitect.com/forum/fil...glow-setup.jpg
If I'm completely off, show me the best way to set it up. Perhaps with a screen image post. That would be very helpful.
Thanks.
Dan J is offline
Old March 4th, 2004   #8 (permalink)
DelfoZ's Avatar
Mexico Send a message via ICQ to DelfoZ Send a message via MSN to DelfoZ
try this
DelfoZ | DS
Citta Nouva
DelfoZ is offline
Old March 4th, 2004   #9 (permalink)
Huhhhhhhhhhhhh! I'm so dense sometimes. Sheesh.
Right click on the object-object properties-G Buffer object channel set to 1 or
Material editor-material assigned with material effect channel set to 1 (or under one of the map channels for more interesting effects), then in the rendering effects-glow element- options tab- images sources object or effects ID set to one of the above choices.
Thanks for jogging my memory a bit.
Dan
Dan J is offline
Old March 4th, 2004   #10 (permalink)
DelfoZ's Avatar
or this :
DelfoZ | DS
Citta Nouva
DelfoZ is offline
