Name: Kelly Sheehan |
I am trying to render my model at a output size of 4000x3000. Now when I send it to my render machine via backburner/Net render it works fine. But if I turn off net render and try and render on my machine it comes up with a Bitmap Error?? It will render fine on my machine at an output size of 2000x1500 though
Name: James Taylor |
sounds like your running low on available memeory when trying to render locally. The maximum render output size links to the available RAM somehow, Aslong as you can render it thro backburner at the needed resolution you shouldn't have a problem?
Name: Virgil Johnson |
memory issue probably
If I am working in Max for a while and I want to render at higher resolutions than the tests I am using, I close out Max and come back. Then I can get what I want. Virgil |
| render error , plz help me | otoperia | 3ds Max | 4 | May 28th, 2007 10:00 AM |
| error render vray | sofad | VRay Render | 5 | August 4th, 2006 01:23 PM |
| Net Render Error | lost in 3d world | Autodesk VIZ | 0 | March 3rd, 2006 05:44 AM |
| VIZ2005 network render error | quizzy | Autodesk VIZ | 9 | May 5th, 2005 07:43 AM |
| Net Render Error 0000274c | lost in 3d world | Autodesk VIZ | 3 | February 8th, 2005 06:20 AM |
