Autodesk VIZ Autodesk VIZ
Old May 10th, 2007   #1 (permalink)
Timothy Saunders's Avatar
Default Viz 2008 / Mental Ray
Anyone know if Viz 2008 has the new features of mental ray (sun and environment, presets and stuff)?
Timothy Saunders is offline
Old May 11th, 2007   #2 (permalink)
Ray
Ray's Avatar
Default Re: Viz 2008 / Mental Ray
This is from the 'What's New' in Viz2008 Help:
  • mental ray 3.5 software adds powerful rendering functionality to Autodesk VIZ 2008. Features include:
    • Create photorealistic sunlight, skylight, and skies with visible sun with the Sun & Sky solution.
    • The new mental ray Arch & Design material improves the image quality of architectural renderings and improves workflow and performance in general and make it easier for designers and architects to create effects such as rounded corners, blurred reflections, frosted glass, and glossy surfaces such as floors.
    • The new mental ray Car Paint material is ideal for re-creating the unique new-car look and feel, with four layers for pigment, metal flakes, clear coat, and, if the car's been on the road a bit, dirt. The same features are also available in the Car Paint shader.
    • Global illumination in mental ray is now far more accessible with final gather presets and easier-to-use controls.
  • When rendering very large images from the command line you can now specify how images are to be split and stitched. See Command-Line Rendering Switches.
Ray is offline
Old May 11th, 2007   #3 (permalink)
Hmm. I may have to go ahead and install it. I'm close to jumping ship on Vray.
Old May 12th, 2007   #4 (permalink)
Justin Hunt's Avatar
Jump in the waters great
Why the jump?
JHV
Justin Hunt is offline
Old May 14th, 2007   #5 (permalink)
Why the Jump Tim?
ralopez is offline
Old May 14th, 2007   #6 (permalink)
Ray
Ray's Avatar
Yeah, why?
Ray is offline
Old May 14th, 2007   #7 (permalink)
Well, I guess I shouldn't be that drastic. But I will deffinately dangle my feet a little. I am just SOOO tired of fighting the memory issues with vray lately. Ya it renders super quality, with lightning speed, and great material options at low resolution. But every scene we do that has a lot of different materials, furniture, different lighting fixtures, etc. has memory issues when it's time to render a 3000px image. I just miss the days when I first started using Vray wihout getting errors. Who knows maybe I just need to uninstall it and go back to an older version. It just seems a shame to leave all those cool new materials behind if I did backstep. I guess that's what I would be doing by switching to Mray, but it's worth exploring when it's free and all.
Old May 14th, 2007   #8 (permalink)
Oh I wouldn't say it's a back step.
The Arch&Design material is as good if not better than the Vray materials. Besides there are also a heap of other shaders available that will give unbelievable control over your renderings. IF thats what you are after.
Sure it would be great to have the proxie objects of Vray but I must say that that is possibly the only feature that I miss. Mray3.5 is a huge improvment over past versions and is very quick.
The Final Gather is very good, so much so that I havnt needed to touch photons since.
The sun and sky system is fantastic. What I also like with the mr Physical Sky shader is that it isn't limited to the environment slot and in itself whilst very simple and straight forward to use it is very powerful.
The Mentalray community has taken a leaf out of Vrays community book and is becoming more and more open, have you taken a look at the mymentalray.com , Masterzaps blog mentalraytips.blogspot.com and not to forget Jeff Pattons blog http://jeffpatton.cgsociety.org/blog/ a wealth of information
JHV
Old May 15th, 2007   #9 (permalink)
Ray
Ray's Avatar
Keep us posted on how it goes.
Ray is offline
Old May 15th, 2007   #10 (permalink)
I'll let you know. It may be a month or two before I produce anything. Who knows what will be shown at Siggraph/DVC this year from either renderers.
How does mental ray handle heavy geometry scenes ? paraganek Other 3rd Party Renderers 25 February 18th, 2008 04:03 PM
Maya v. Mental Ray Shaders hd_leach Maya 3 May 9th, 2007 12:13 PM
Mental Ray goes 64 bit vizwhiz Maya 0 July 28th, 2005 08:03 PM
Max 7 Lights with Mental Ray OllyNicholson 3ds Max 9 July 21st, 2005 02:13 PM
