Name: Hector Pascalidis |
Hi:
This relate to my previous post. Given that I am rendering an interior shot I need to know if there is a way of getting the transparency values preserved (when you look outwards through the glass) and the background removed so I can composite a new background in photoshop. I do this in Lightwave by saving the image as a 32 bit tiff but how do I achieve tha same in Modo? Regards Hector |
Hi,
thanks for your repply. It seems that there is no tiff export option. I've tried PNG and Targa, both save an alpha channel but... I have to open the file in photoshop, load the alpha channel as a selection and then create a mask with that selection to remove the backgroung (environment) behind the glass. The problem is that the alpha channel does not register reflections on the glass, so once I use the AC to do the mask, reflections are gone. Any ideas? |
#4 (permalink) | |
Name: Ahmed Alireza |
| alpha channel | lefks | VRay Render | 4 | December 8th, 2006 07:09 AM |
| Luxology Releases modo 202 | Jeff Mottle | Modo | 0 | August 9th, 2006 09:56 PM |
| create an alpha channel? | nazcaLine | Photoshop | 5 | April 6th, 2006 05:19 AM |
| compositing in photoshop with alpha channel | Munz | Photoshop | 4 | November 16th, 2004 06:00 PM |
| Architectural glass opacity missing alpha channel | Ras | Autodesk VIZ | 3 | November 15th, 2004 02:02 AM |
