| Modo Luxology Modo |
#11 (permalink) |
No, Mesh Items are the equivalent to layers. Group Locators are what their name suggest, groups. You can nest several mesh items into another mesh items if you wish. Group Locators come in handy whenever you want to translate several items together. Other than that they help to organize your file.
#12 (permalink) |
Cool. Thanks for shedding some light on that.
As for modeling completely in Modo...baby steps on that one. First, I need to see render quality...and if I end up liking the look and performance, I'll slowly migrate perhaps. Just need some material and outdoor lightings tuts and tips now... Last edited by RyanSpaulding; July 9th, 2007 at 10:22 AM. |
#13 (permalink) |
Here are some Material presets:
http://www.vertexmonkey.com/presets_collections.php and a tutorial on how to use them: http://www.nullinstitute.com/web/Nul...B5EDB99E8.html Shader Tree Tuts: http://www.vertexmonkey.com/tutorial...shaderTree.php Tutorials on lighting and rendering: http://www.vertexmonkey.com/tutorials_lighting.php http://www.vertexmonkey.com/tutorials_rendering.php |
#16 (permalink) |
GETTING 2D CAD DATA INTO MODO (Via MicroStation XM + Deep Exploration 5.0)
USEFUL LINKS: http://forums.luxology.com/discussio....aspx?id=13431 http://forums.luxology.com/discussio....aspx?id=13233 DWG to DXF Workflow Option In Export Settings: Entity Mapping > Convert All to 'Polylines' when possible Condense levels as much as possible until Modo 301 Drop All Elements to linework Found some translations when put into Modo via X's DXF get flipped, such as with arcs Anything not dropped does not translate Open In AccuTrans Save As a large LWO file Fast and Accurate DWG to LWO Workflow Option CAD Version of Deep Exploration used for DWG > LWO DWG to LWO Export Sometimes loses line color data in translation Computer Inensive DWG to DXF to LWO Workflow Option CAD Version of Deep Exploration Used for DXF > LWO Same as above, with line color maintained Computer Intensive GETTING 3D CAD DATA INTO MODO (Via MicroStation XM + Deep Exploration 5.0) MicroStation XM > U3D > LWO CAD Version of Deep Exploration Used Level Structure Does Not Remain after Save of LXO File Must go through each level (mesh), find greyed out levels (meshes), delete these (do not delete child objects) Then Move geometry that collapsed to ouside of tree to the inside of the level (mesh) desired Right-Click > Convert to 'Group Locator' Now the LXO file will reopen with selectable levels (meshes) Last edited by RyanSpaulding; July 23rd, 2007 at 01:25 PM. |
#17 (permalink) |
Ok, I'll update here as well, but I've created a small site called MicroStation to Modo. i'll have more in depth and better formatted stuff here. It's specific to MicroStation, but a lot of the info is general for you Autodesk users.
http://www.ryan-spaulding.com/cad_to_modo/ A WIP, but we, the arch viz crowd, need this. |
| Null's modo Preset Library for modo 203 | Yazan | Modo | 3 | April 14th, 2007 02:30 PM |
| Microstation + Maxwell WIP image | Phil Shields | MicroStation | 5 | December 12th, 2006 11:14 AM |
| Luxology Releases modo 202 | Jeff Mottle | Modo | 0 | August 9th, 2006 08:56 PM |
| modo...Modo...MODO...! | wda | Suggest a New Forum | 18 | June 3rd, 2006 11:36 PM |
| Scaling with line weights | Sawyer | AutoCAD/AutoCAD Architecture | 8 | December 15th, 2005 04:51 AM |
