Go Back   CGarchitect.com > 3D SOFTWARE > Modo
Modo Luxology Modo
Old July 9th, 2007   #11 (permalink)
CHE
CHE's Avatar
United_States  Send a message via MSN to CHE
Default Re: My jump into Modo via MicroStation XM (WIP)
No, Mesh Items are the equivalent to layers. Group Locators are what their name suggest, groups. You can nest several mesh items into another mesh items if you wish. Group Locators come in handy whenever you want to translate several items together. Other than that they help to organize your file.
CHE is online now
Old July 9th, 2007   #12 (permalink)
Name: Ryan Spaulding
Cool. Thanks for shedding some light on that.
As for modeling completely in Modo...baby steps on that one. First, I need to see render quality...and if I end up liking the look and performance, I'll slowly migrate perhaps.
Just need some material and outdoor lightings tuts and tips now...
RyanSpaulding is offline
Old July 9th, 2007   #13 (permalink)
CHE
CHE's Avatar
Here are some Material presets:
http://www.vertexmonkey.com/presets_collections.php
and a tutorial on how to use them:
http://www.nullinstitute.com/web/Nul...B5EDB99E8.html
Shader Tree Tuts:
http://www.vertexmonkey.com/tutorial...shaderTree.php
Tutorials on lighting and rendering:
http://www.vertexmonkey.com/tutorials_lighting.php
http://www.vertexmonkey.com/tutorials_rendering.php
CHE is online now
Old July 9th, 2007   #14 (permalink)
Che, you're the man!
Old July 9th, 2007   #15 (permalink)
CHE
CHE's Avatar
No problem. I hope you find a way to incorporate Modo into your work flow.
CHE is online now
Old July 23rd, 2007   #16 (permalink)
GETTING 2D CAD DATA INTO MODO (Via MicroStation XM + Deep Exploration 5.0)
USEFUL LINKS:
http://forums.luxology.com/discussio....aspx?id=13431
http://forums.luxology.com/discussio....aspx?id=13233
DWG to DXF Workflow Option
In Export Settings: Entity Mapping > Convert All to 'Polylines' when possible
Condense levels as much as possible until Modo 301
Drop All Elements to linework
Found some translations when put into Modo via X's DXF get flipped, such as with arcs
Anything not dropped does not translate
Open In AccuTrans
Save As a large LWO file
Fast and Accurate
DWG to LWO Workflow Option
CAD Version of Deep Exploration used for DWG > LWO
DWG to LWO Export
Sometimes loses line color data in translation
Computer Inensive
DWG to DXF to LWO Workflow Option
CAD Version of Deep Exploration Used for DXF > LWO
Same as above, with line color maintained
Computer Intensive
GETTING 3D CAD DATA INTO MODO (Via MicroStation XM + Deep Exploration 5.0)
MicroStation XM > U3D > LWO
Level Structure Does Not Remain after Save of LXO File
Must go through each level (mesh), find greyed out levels (meshes), delete these (do not delete child objects)
Then Move geometry that collapsed to ouside of tree to the inside of the level (mesh) desired
Right-Click > Convert to 'Group Locator'
Now the LXO file will reopen with selectable levels (meshes)
Old July 24th, 2007   #17 (permalink)
Ok, I'll update here as well, but I've created a small site called MicroStation to Modo. i'll have more in depth and better formatted stuff here. It's specific to MicroStation, but a lot of the info is general for you Autodesk users.
http://www.ryan-spaulding.com/cad_to_modo/
A WIP, but we, the arch viz crowd, need this.
Null's modo Preset Library for modo 203 Yazan Modo 3 April 14th, 2007 02:30 PM
Microstation + Maxwell WIP image Phil Shields MicroStation 5 December 12th, 2006 11:14 AM
Luxology Releases modo 202 Jeff Mottle Modo 0 August 9th, 2006 08:56 PM
modo...Modo...MODO...! wda Suggest a New Forum 18 June 3rd, 2006 11:36 PM
Scaling with line weights Sawyer AutoCAD/AutoCAD Architecture 8 December 15th, 2005 04:51 AM
