Go Back   CGarchitect.com > 3D SOFTWARE > Modo
Modo Luxology Modo
Old July 12th, 2007   #1 (permalink)
Default semi transpaent glass or
hello I'm trying to do some render test,s i'm new to modo i have a LW background. So here it is seethe image bellow. One side of the glass panel shoul be normal glass, like standard transparent glass, the other i wanted to be like a semitransparent glass, see reference image with the plant. Objects should be blurred when seen trhougth the glass. Any body have any idea? blur reflections is checked, from where can i boost the bluryness on the material
Thank you all
claudioarchi is offline
Old July 12th, 2007   #2 (permalink)
Default Re: semi transparent glass
this is only a test
Old July 12th, 2007   #3 (permalink)
chiquito's Avatar
Argentina
yes, if you are using Vray, try varying the refraction glossines should give you that effect, the further away from 1 to 0 (ej 0.6) the more blur you will have on your translucency. Good luck
chiquito is offline
Old July 12th, 2007   #4 (permalink)
i'm sorry i don't have acces to vray this is a modo rendering. It is easy to do it in LW with nodes but i just want to test modo capacities. Thanks any way
Old July 16th, 2007   #5 (permalink)
Belgium
Default Re: semi transpaent glass or
Hi,
You can control the amount of blurry reflection with the "Roughness"-value.
Good Luck!
AlbertoEzzy is offline
Fritted Glass in Modo and generally Hector Modo 2 May 11th, 2007 04:41 PM
glass reflections jccloutier VRay Render 10 July 25th, 2006 07:20 AM
colored light behind frosted glass...making glass glow? bigsilly 3ds Max 1 May 5th, 2006 09:07 AM
vray glass Timothy Saunders VRay Render 10 March 20th, 2006 01:24 PM
Problems with glass... Koskinen Lightscape 9 July 23rd, 2004 07:19 AM
