Name: claudio nunez |
hello I'm trying to do some render test,s i'm new to modo i have a LW background. So here it is seethe image bellow. One side of the glass panel shoul be normal glass, like standard transparent glass, the other i wanted to be like a semitransparent glass, see reference image with the plant. Objects should be blurred when seen trhougth the glass. Any body have any idea? blur reflections is checked, from where can i boost the bluryness on the material
Thank you all |
Name: Martin Norris |
yes, if you are using Vray, try varying the refraction glossines should give you that effect, the further away from 1 to 0 (ej 0.6) the more blur you will have on your translucency. Good luck
| Fritted Glass in Modo and generally | Hector | Modo | 2 | May 11th, 2007 04:41 PM |
| glass reflections | jccloutier | VRay Render | 10 | July 25th, 2006 07:20 AM |
| colored light behind frosted glass...making glass glow? | bigsilly | 3ds Max | 1 | May 5th, 2006 09:07 AM |
| vray glass | Timothy Saunders | VRay Render | 10 | March 20th, 2006 01:24 PM |
| Problems with glass... | Koskinen | Lightscape | 9 | July 23rd, 2004 07:19 AM |
