Go Back   CGarchitect.com > POST PRODUCTION SOFTWARE > Photoshop
Photoshop Adobe Photoshop
Old August 8th, 2007   #1 (permalink)
Venezuela
Default adding a background behind a window
Ok, adding a background in PS is easy, I just either save my file in MAx as .png or Targa, so I wont have the background.
But heres the thing, im doing a interior scene, wher ethe cam looks to the outside, through a huge glass window, actually a curtain wall, so I cant use the same trick because I want to keep the reflections on the window, that meanst I render with the glass, so I cannot separate the max background in some alpha channel.
ANy ideas on how to tackle this sorta thing?
Im guessing Im stuck with adding the background I want in 3d MAX, but the colors are way off, so I was wondering if there were some tricks in photoshop for this.
salf is offline
Old August 8th, 2007   #2 (permalink)
edub's Avatar
Default Re: adding a background behind a window
try playing with the layer modes (multiply, overlay, etc.) Your best bet is probably if you can get a white background behind the window without washing out the reflections.
edub is offline
Old August 26th, 2007   #3 (permalink)
Exellite's Avatar
when you save as a tiff or something that can store alphas it stores the reflections as well, they just show up as less transparent on the alpha channel.
Exellite is offline
Old August 31st, 2007   #4 (permalink)
Russian Federation Send a message via ICQ to AlNe Send a message via MSN to AlNe
Use inverted Alpha channel for a background mask and "Screen" blending mode for it.
AlNe is offline
Old September 5th, 2007   #5 (permalink)
nazcaLine's Avatar
Peru
if you are using vray, then when creating a glass there is an option in the refraction section called "affect alpha" (or something like that). if you check it, you'll be able to keep the reflections and alpha. good luck
Eduardo
"I have nothing to do with the real world anymore. Please don't insist."
Eduardo Romero
nazcaLine is offline
Arch. Desktop: double hung window in a curved wall?! Aspiring Visualizer! AutoCAD/AutoCAD Architecture 2 May 1st, 2008 07:18 PM
Creating Background...pls Help Ghan General Discussions 1 May 4th, 2007 09:29 AM
Adding a Background baker1444 VRay Render 5 October 23rd, 2006 11:10 PM
background bitmap drvox VRay Render 5 October 16th, 2006 02:33 PM
window animation, noob help Pumuckle General Discussions 2 July 1st, 2004 06:17 PM
