3ds Max Autodesk 3ds Max
Old August 9th, 2007   #1 (permalink)
Name: tom pouliasis
Greece
Default nurbs problem??
hello people!
i have the following problem with nurbs...
i try to make a tensile architectural structure with nurbs surface tools.
i make some cv curves and then i use U loft to make the surface.
The problem is that the surface is one sided..i press flip normals so i can see the surface but when i go to the back side of the surface there is no surface !! this is a major problem cause i want to show not only the structure from outside but also the interior environment!!
the problem also appears with cross section and surface modifier..
another question is if it is better to use U loft or UV loft for the tensile structure..(or what is the best way to make a tensile structure with nurbs??)
please help!!!
to_po is offline
Old August 9th, 2007   #2 (permalink)
Jordan
Default Re: nurbs problem??
hi....all .....iam eng.tamer bader from jordan ....i am realy overwhelmed about this wonderful site .
i just wanna say something about the nurb problem :
source : a specialized book in 3ds max5
follow these steps
1- right click on the top left of the 3ds max screen ....configure ...force 2 sided
2- rendering parameters f10 : nurbs is working very well with (active shade)
and don't forget to check (force 2 sided ) too . then render
3- use multi sub object all the time ...in conjunction with nurbs modelling ( just if u wanna assign materials )
those 3 streps are extremely improtant ...
click2006click is offline
Computer Problem? Need Help? Check Here First! Greg Hess Hardware and Technical Discusions 7 August 22nd, 2008 05:38 PM
highend 3d modeling nurbs on mac ! Paul@macbidouille General Discussions 23 June 12th, 2007 03:20 PM
nurbs modeling problem atp-design 3ds Max 1 September 3rd, 2006 01:26 AM
File Link Problem... demo38 3ds Max 0 April 13th, 2005 10:50 AM
