Autodesk VIZ Autodesk VIZ
Old August 14th, 2007   #1 (permalink)
Default Viz Object Glow help!
I have Viz 2005.
I'm looking for ways to add a glow to an object. I read some tutorials online. Is Video Post is required? I don't have Video Post.
http://www.cgarchitect.com/vb/11470-...ject-glow.html
I tried the Effects > Lense > Glow but it doesn't work with the object ID or Effects ID... am I missing something?
Help! thanks in advance.
Lily Wei is offline
Old August 14th, 2007   #2 (permalink)
Default Re: Viz Object Glow help!
the effects>glow is for your light source I believe. If you want your object to glow add self-illumination to it and make transparent - add an opacity map and place an omni light inside your object, then apply the effects>glow to the omni.
If you are using V-ray then apply the vray lightmaterial to it and make transparent. The vray material will bounce light off the objects around it, then you just have to adjust the strength to look right.
ipxstudios is offline
Old August 15th, 2007   #3 (permalink)
Hi ipxstudios,
I'm trying to apply a glow to an object, not to a light. For example, create a 3D letter, and apply a glow around the letter to make it look like it's rear-illuminated. The glow should look like it's evenly distributed and should be in the exact shape of the letter.
THanks
Lily Wei is offline
Old August 23rd, 2007   #4 (permalink)
Ireland
Lily,
you could use Blur in render effects and get it to only bur the material on the object you want to glow, but set the blur to illuiminate. I think. I haven't done this in a while, but I think that is how you do it.
Hobo Monstrocity is offline
Old August 24th, 2007   #5 (permalink)
r2
did you assign a material in the material editor the correct effects ID number? in the glow element tab under options, checkmark the effects ID, pick any number. Go to your material editor, pick a material for the glowing object and change the default "0" to the same number as in the effects ID. I usually use a glow size of .1 for letters and play around with the intensity to not blow out the screen. Something around 75 is ok. Hope this makes sense.
r2 is offline
Old August 24th, 2007   #6 (permalink)
Thank you Hobo and r2, I did finally make it work by adjusting the options in glow effect. I'm all set!
Lily
Lily Wei is offline
Object Glow? Dan J Autodesk VIZ 12 August 14th, 2007 03:41 PM
why is one object not one object RAYMOND Autodesk VIZ 4 November 7th, 2005 12:00 PM
combine object by layer rayray 3ds Max 1 July 24th, 2005 10:09 AM
how do I make an object glow Munz 3ds Max 5 July 18th, 2005 01:07 PM
