Go Back   CGarchitect.com > 3D SOFTWARE > Lightwave
Lightwave Lightwave
Old August 14th, 2007   #1 (permalink)
Malaysia
Default Getting rid of flicker - what render setting to use
Hi guys,
I am wondering if another Lightwaver can share the secrets to eliminating flickers when doing animation.
There are particularly pronounced when there are a lot of detailed geometry.
I have been setting my render at 9 pass antialiasing with photoreal motion blur but still not quite happy with the result.
What setting do you use? Thanks
thinice is offline
Old August 16th, 2007   #2 (permalink)
Name: Florian v. Behr
Germany Send a message via ICQ to Limbus Send a message via Skype™ to Limbus
Default Re: Getting rid of flicker - what render setting to use
Can you show an example of the flicker?
Cheers, Florian
www.florianvonbehr.de
Limbus is offline
Old August 16th, 2007   #3 (permalink)
IC
IC's Avatar
Scotland
Are you rendering out stills and then putting them together?
What system/codec do you use when compiling your movie?
http://iainc.carbonmade.com/
IC is offline
Old August 17th, 2007   #4 (permalink)
Malaysia
Flicker comes up when I encode it into animation format. I tend to use mpeg2 format but it tends to come out with any other high resolution, high sharpness format as well.
I need to give you the full resolution clip to show the flicker. Once compressed into smaller files, it is not the same thing anymore. I'll think of something.
thinice is offline
Old August 17th, 2007   #5 (permalink)
So there is no flicker in the images coming out of lightwave? Is that correct?
Have you tried using a more modern codec like h.264. It included in Quicktime and there is also a free version called x.264.
I guess 2 frames would be enough to see the flicker.
Cheers, Florian
Limbus is offline
1.5 final HAS BEEN RELEASED tdarcy VRay Render 13 August 9th, 2007 11:24 AM
Weird Render Error?? AFK_Matrix 3ds Max 2 May 9th, 2007 04:34 AM
request to criticise the work anindia Work in Progress (WIP) 4 April 5th, 2006 02:47 AM
Render Elements Crash lebbeus 3ds Max 0 December 5th, 2004 10:51 AM
cinema 4d PiNkFlUiD Finished Work 13 February 28th, 2003 05:00 AM
