Old August 16th, 2007   #1 (permalink)
shikodesign2000's Avatar
Default Question..
Hi,
I know that this is not the suitable section for this question, cause I want to ask something in Combustion, I posted in the proper section, but no answers, I hope to be answered from anyone who have some experience in this software.
My question is: How can I make fade "to black" or "from black" for any animation video? also, how can I make transitions?
Sorry again, but really this can affect very much my present project
Best Regards,
Sherif Massoud
www.3dshore.com
shikodesign2000 is offline
Old August 16th, 2007   #2 (permalink)
Name: Alain Blanchette
Default Re: Question..
Turn off incremental save and backup on save when using DR.
Save before sending the render. Should fix it
Thablanch is offline
Old August 17th, 2007   #3 (permalink)
Sorry, but I didn't get you can you explain more plz??
Best Regards,
Sherif Massoud
www.3dshore.com
Old August 17th, 2007   #4 (permalink)
in your composite hierachy you should have the name of your imported file...
ie..film footage...rght click on that and got to---operators---transitions----gradient wipe.
you can adjust the values of the gradient wipe and animate to what ever time scale you require.
you can also have multiples of this transition, just copy and paste and adjust as desired.
be sure to set your base background to black.
jonblaze is offline
Old August 17th, 2007   #5 (permalink)
in the menus:
customize > preferences > opens dialog box
files tab >
files handeling sections.
Uncheck backup on save and increment on save.
The reason why: I do not know..., but is was documented in previous builts, not to use theses features. seems that this is still following. I always forget to turn them off.
Old August 17th, 2007   #6 (permalink)
Thank you very much for your explanaition, I'm appreciating this too much.
I want to ask you another question: how can I make transitions between 2 videos? and where the interesting transitions in combustion?
Plz tell me specific steps like you did in fading solution.
Best Regards,
Sherif Massoud
www.3dshore.com
Old August 22nd, 2007   #7 (permalink)
I do not use combustion that much, only for particles stuff.. usually I use AE.
If you are looking for an editor only (stitching sequences) SONY vegas is a nice toolset. simple, efficient.
Old August 22nd, 2007   #8 (permalink)
Thanks Alain for your suggestion, but thanks GOD, after some trials, I get what I want, maybe some time I'll try your software, just some free time
Best Regards,
Sherif Massoud
www.3dshore.com
Question: very basic scripting question batteryoperatedlettuce Scripts 1 February 21st, 2007 09:53 AM
Yet another computer question: C2T7200 vs C2 E6400 Arnold Grove Hardware and Technical Discusions 7 November 26th, 2006 09:40 PM
Interior design question skauty General Discussions 7 September 15th, 2006 01:11 PM
The typical newbie question i am sure... VRay or Brazil? rafaelsrocha Autodesk VIZ 10 January 31st, 2006 10:30 PM
simcloth question + 3ds max6 haneet khanna 3ds Max 4 November 9th, 2005 11:32 AM
