Go Back   CGarchitect.com > 3D SOFTWARE > SketchUp
SketchUp @ Last Software SketchUp
Old September 4th, 2007   #1 (permalink)
Duchess's Avatar
Default Position Texture Tool
Okay, so I'm having an issue with the position texture tool. I'm using an evaluation version of SketchUp Pro, and I can't seem to find the position texture tool! This is what the help menu says:
Repositioning a Material
Repositioning the material is the easiest of position texture operations. To reposition a material:
  1. <LI class=list value=1>Context-click on the material to display its context menu. <LI class=list value=2>Select the Position option from the Texture sub-menu. A matrix of dotted lines is displayed on the material to indicate the material's individual tiles. The cursor also changes to a hand and four pins are displayed. <LI class=list value=3>Drag the cursor on the surface to reposition the texture on that surface. If you want to rotate the tiled image, context-click on the surface again and select Rotate or Flip.
  2. When you are finished modifying the texture, context-click and select Done, or just click outside the texture to exit the Position Texture Tool.
HOWEVER.. when I context click on the face, all I see is this:
Am I doing something increadibly wrong? Or is maybe the evaluation version void of this feature?
Duchess is offline
Old September 6th, 2007   #2 (permalink)
Default Re: Position Texture Tool
Duchess,
Can't tell for sure from the image - but is the texture on a curved surface? I can get the texture position option to come up in both the pro and free version on flat surfaces. I never tried on a curve until i saw your post - doesn't work on a curved surface for me in either version. I will try to find an answer, but can you try on a flat surface to make sure you get the option that way.
Thanks,
Dean
bytor is offline
Old September 7th, 2007   #3 (permalink)
Duchess's Avatar
Oh, that is LAME. The whole reason I was trying to move the texture is because I couldn't add real windows to a curved surface.
I really don't like Sketchup.
Duchess is offline
Old September 13th, 2007   #4 (permalink)
Burk's Avatar
Germany
You can set Hidden Geometrie and made it step by step
Or change one part of the Texture to the right position and take the color picker for this texture part. Now you can apply it again on the other faces and all should be on the right position.
Burk is online now
Old September 14th, 2007   #5 (permalink)
you could also project the texture onto the curved surface instead of mapping it onto the surface.
rmoore97 is offline
Move Position Problem Chris Potts 3ds Max 3 January 27th, 2006 02:28 PM
Combustion Texture Map.......Help! JamesTaylor Compositing Software 4 December 9th, 2005 02:07 PM
Mesh to Texture holes in solution exception Lightscape 9 November 12th, 2004 04:06 AM
Road Texture Map P.R.S. Sivakumar General Discussions 9 June 18th, 2004 03:47 AM
Texture problem Mental Ray Chucky Maya 2 October 10th, 2003 07:51 PM
