Old September 17th, 2007   #1 (permalink)
Default mental ray: glass material
There are quite a few mental ray glass material settings and shaders available for use. Could anyone tell me which one is the best for the exterior glass curtain wall?
Based on my limited experience, the following are what I found three types of Glass:
1. from Arch & Design template:transparent material > glass >solid geometry
2. mentral ray > surface shader > dielectric material
3. glass (physical phen)
Thanks for your input in advance,
smr_VIZ is offline
Old September 17th, 2007   #2 (permalink)
shaneis's Avatar
Default Re: mental ray: glass material
If you need clear/ coloured physically accurate glass, use the dielectric material. Set the IoR to 1.5 - 1.6 and you're done.
If you need the glass to have custom characteristics, such as a sand-blasted or geometric patterning, the A&D material would be easier to set up.
shaneis is offline
mental ray glass material smr_VIZ Autodesk VIZ 2 October 7th, 2007 09:36 PM
help creting mental ray material sachinwalvekar 3ds Max 1 September 5th, 2006 07:04 PM
Help with grass & glass with mental ray jonrempel Work in Progress (WIP) 2 July 10th, 2006 09:44 AM
mr problem with glass mr material with dielectric msamer 3ds Max 9 April 6th, 2006 11:34 AM
