| Autodesk VIZ Autodesk VIZ |
Name: James Taylor |
Whats the best way to assign individual UVW maps to individual elements of a single object?
from the attached screen grab you can see that i have a no. trusses making up a pergola. I would like to assign a cyclinder uvw to each individual element so a wood map can be applied wrapped around each one. My plan was then to use MaterialByElement to assign a no. of varied materials to the elements. Also, the model has been file linked from AutoCAD, as such i would like to keep the link in place so that it can still easily be updated... what i don't want is to spend ages going through each element one at a time and then have to do it again when the client decides to changes thing, as the site contains 10 or so structures of this nature. |
or... how can i assign random materials (in a simialr manner to how MaterialByElement works) to a no. of different objects without having to do it manually??
Name: Martin Norris |
I had a free plug in, checker box or something like that, I lost it and really would like to get it, cant recall its name, something like dashboard id, or similar.... Yo made a selection of poligon, and entered the amount of ids, and it assigned them randomly, from there to a multi material.
Here's the Solution..but fully working version is not free
http://www.vg2max.spb.ru/PolygonMap.htm cheers Meher www.mr-cad.com |
Martin, i think the plug in your talking about is dashboard id by Uniform's Sam O'Hare... you can pick it up at www.pixelpollen.co.uk (or whatever his web site address is - find one of his posts its listed in his footer i think).
The problem for me is that i want to assign the same id to all the faces of an element, but i want different elements of an object to have randomly asssigned values. Meher, thanks for the link - looks interesting but i'm not 100% sure its gonna do what i envisage. I've ended up just biting the bullet and assign each UVW map individually as a instance, it didn't actually take too long but i still hope they don't change anything on these elements!! Its time like these that knowing Maxscript would be invaluable. |
Could you not just use a Multi/Sub-object material and assign different id's for each direction, then apply a UVW map for each id? Or detach the elements with matching directions to seperate objects and apply a UVW map for each object, then apply a single material to the whole thing. Or don't bother with UVW maps and use real-world coordinates, remembering to check generate mapping coordinates and real-world coordinates when creating your objects.
| Vrl Map Vs Vr Map | nivvu | VRay Render | 3 | July 6th, 2007 08:10 AM |
| problem with uvw map and multi/sub-object maps | cakewalkr7 | 3ds Max | 5 | December 31st, 2006 07:48 PM |
| Multi/Sub Object UVW mapping | thickly | Maxwell Render | 1 | January 16th, 2006 12:22 PM |
| importing and uvw map applying autocad model in 3ds MAX | j.k | 3ds Max | 3 | May 13th, 2004 11:20 PM |
