| Autodesk VIZ Autodesk VIZ |
Name: Jason Matthews |
Hey everyone. I am working on a project that has pool deck with a lot of curved paving patterns. Is there a way to map the UV along the curves? Or do I have to model each paver? I am modeling with Sketchup and rendering with Viz and Vray.
Jason Matthews |
Name: Chad Warner |
Best bet for that would be to create the path lines in sketchup and then use those lines with either the sweep modifier or a loft, and have the sweep generate mapping coordinates. You may have to adjust the tiling in the map to get the right scale on each paver.
This method works real well unless you have a curve followed by a sharp corner, in which case the mapping gets screwy. |
| UV mapping | warprat | Lightwave | 5 | October 11th, 2006 06:52 PM |
| Curved Walls | drvox | 3ds Max | 4 | October 5th, 2006 08:21 PM |
| UVW mapping question. | salf | 3ds Max | 3 | July 15th, 2005 01:40 PM |
| Mapping a curved road | rcase | 3ds Max | 4 | April 10th, 2005 03:16 AM |
| mapping gizmo transformation !!?? | virses | 3ds Max | 1 | September 21st, 2004 05:07 AM |
