Old October 3rd, 2007   #1 (permalink)
Default Seleting the objects in camera angle
hi all.....
i have a problem selecting the objects in max......
let me explain me in brief.....
iam suppose to generate interior images for a college building.....there is a huge revit file of the college building which i imported in max.....it has got so many objects.....i have freezed on the camera angles......now i want to delete all the other objects which i am not able to view in camera angle....
now is there any script or any command by which i can select the objects at a time which iam viewing in camera and deleting them......rather than manually selecting objects and then deleting them.........(usually we do select objects by color, name or materials applied at a time)......so thrz anything for camera by which we can select the objects which a camera is viewing........
thrz one more option tooo.....we can go in camera viewport and select the objects in camera viewport but i dont want to do like tht.....
hope u guys understood my problem
plz advise
thanks in advance
nivas
nivvu is offline
Old October 4th, 2007   #2 (permalink)
Default Re: Seleting the objects in camera angle
any one please..................
nivvu is offline
Old October 4th, 2007   #3 (permalink)
Name: Alain Blanchette
I would use the standard Named Selections Sets, in the standard toolbar, you could give the selected items you camera name, reverse selection and hide items, and so on for the other cameras.
I think it is faster to do that than to look/build a script doing that
Thablanch is offline
VI and Camera Placement (for Devin "Maxer") Virgil Johnson General Discussions 1 February 6th, 2007 06:36 AM
limited DOF crazy homeless guy General Discussions 6 November 29th, 2006 05:18 PM
simplify a model? Robeast Autodesk VIZ 7 May 19th, 2006 06:30 AM
adjusting real camera angle with max camera edward80 3ds Max 1 March 26th, 2006 11:18 AM
Flat Mirror and Camera Correction chapmandu Autodesk VIZ 1 July 9th, 2003 04:42 AM
