Autodesk VIZ Autodesk VIZ
Old October 4th, 2007   #1 (permalink)
Timothy Saunders's Avatar
Default Top / Bottom Material
I have 2 stucco colors I want to put on some walls. I can only see the top color. To test it, I can apply the mat to spheres, teapots & toruses and it works fine. But, any time I put it on n object with a straight edge like a wall, a box, or even a cone, it only shows one color. What's up with that?
Timothy Saunders is offline
Old October 4th, 2007   #2 (permalink)
gfa2's Avatar
Default Re: Top / Bottom Material
I tried it just like you did but in max and I'm getting the same results. Works fine on a teapot and torus, but no go on a box. I thought it might just need a UVW mapping modifier or a different material ID...but I can't get anything to work on a straight surface.
gfa2 is offline
Old October 5th, 2007   #3 (permalink)
Bulgaria
""The object's top faces are those whose normals point up. The bottom faces have normals that point down. You can choose whether "up" and "down" refer to the scene's world coordinates or to the object's local coordinates.""
In your box all side faces are with one normal pointing at 90 degrees in world coordinates.
In cone situation is the same, but all side polys are with normals pointing up.
ameo is offline
Old October 5th, 2007   #4 (permalink)
Local still doesn't work on straight walls. I'll just go back to my old method of using a white and black mask map used on a blend material.
Old October 5th, 2007   #5 (permalink)
Bulgaria
No matter local or world coordinates, all side faces have same normal from Z origin (90 degrees) and will be with same material (top or bottom), you cannot use this material in your case.
ameo is offline
shell material v-cube 3ds Max 1 May 19th, 2006 09:31 PM
mr problem with glass mr material with dielectric msamer 3ds Max 9 April 6th, 2006 11:34 AM
