Old October 14th, 2007   #11 (permalink)
Randy's Avatar
Default Re: Lightscape & Win x64 - It's working
Migrated the folder to XP x64 & Win2003 x64 with and without installed SP's (SP1 & SP2).
Since Vista SP1 is not official and I dont have it, I could not try LS on Vista SP1.
Randy is offline
Old October 14th, 2007   #12 (permalink)
Originally Posted by Randy View Post
You mean Lightscape SP1? No Problem, because all the informations are stored in the registry. Installation went just fine.
The screenshot above is LS 3.2 SP1 - thanks to seismograph for the SP1.
Confuse man, sorry, I mean LS SP1, how did you do that?
Installed LS SP1 on 32bit PC and then migrate or install on 64bit PC on already migrated folder?
okmijun is offline
Old October 15th, 2007   #13 (permalink)
Randy's Avatar
Does'nt matter. You can install LS SP1 before migrating - on the 32bit system. Or you can install on the x64 system. Because after adding the reg keys, LS is offically installed, with all system paths. So the updater is able to find your LS 3.2 program location.
Only the add/remove feature in the control panel is missing - but who wants to uninstall Lightscape?
Randy is offline
Old October 15th, 2007   #14 (permalink)
Thats right!
Thanks!
okmijun is offline
Old October 15th, 2007   #15 (permalink)
rotten42's Avatar
Two big thumbs up!!!!
Mental Health is over-rated
rotten42 is offline
Old February 25th, 2008   #16 (permalink)
CreativeElixir's Avatar
excellent post!! Thanks for info!!
CreativeElixir is offline
Old March 1st, 2008   #17 (permalink)
Sweden
This is the very same solution I posted a few months ago
http://www.cgarchitect.com/vb/26663-...tch-vista.html
Cheers
Johan Sae-Thao
djmj is offline
Old September 3rd, 2008   #18 (permalink)
Running Lightscape on 64bit OS would allow LS to se 8GB of memory and even more, correct?
Sice this would be 64bit OS its limit is 8GB, I think....
Beeeee!
del82 is offline
Old September 3rd, 2008   #19 (permalink)
manta's Avatar
No since Lightscape is a 32bit program it will only be able to use 4gigs, and it will never be upgraded to a 64bit program...sorry
DESIGN FORWARD
http://www.mantastudios.com
manta is offline
Old September 3rd, 2008   #20 (permalink)
One thing I dont understand...
Ive tested my old C2D on 2,80 GHz with 2GB ram VS. quad on 2,50 GHz with 4 GB of RAM... radiosity processing time was the same!
What are the resons for this?
...is it because LS doesnt see more then one core when processing? ... in that case I had a pure situation of 2,80 GHz agains 2,50 GHz....this seems logical!
But then again the question of memory remains....if one system had 2 GB and the other 4 GB, and both have 2,50 GHz of CPU power....shouldnt one be faster in processing then the other?!?!
Im running WinXP-32bit
Thanx!
Beeeee!
del82 is offline
Lightscape Scripts for max molson Scripts 10 July 25th, 2008 05:39 AM
installing win xp pro x64 on MacPro mesht Hardware and Technical Discusions 8 March 18th, 2007 08:46 PM
(Old Topic) Lightscape versus XP or ? dbillo Lightscape 27 April 8th, 2005 03:53 PM
Graphic card for lightscape. Lidia Lightscape 13 March 24th, 2005 12:02 PM
lightscape to be retired stephen gilbert Lightscape 14 December 22nd, 2002 10:11 AM
